98 superhawk no start no lights need help asap!!
Old 08-19-2010 | 12:39 PM
SloatsburgSuperhawk's Avatar
SloatsburgSuperhawk is on a distinguished road
i checked the fuses they are all ok.. there is power across the starter solenoid.. the 3 prong black fuse has continuity.. terminals are tight and clean.. i dont know what to do.. please adivse if you have a list of things to go thru..
thanks kevin
Old 08-19-2010 | 12:44 PM
CascadeRider's Avatar
CascadeRider is on a distinguished road
Ignition switch?
Old 08-19-2010 | 12:47 PM
im not too sure yet becasue i still think it could be something stupid... i got on bike drove about a mile.. got a phone call.. pulled over turned key off.. sat down.. 10 mins later got on bike, no start no lights wont jump..unplugged and checked some connections.. idk what to check next
Old 08-19-2010 | 12:55 PM
Did you check the 30A main fuse that is not in the fuse block? It's by the starter relay....
Old 08-19-2010 | 12:59 PM
Stevebis1's Avatar
One possibility is a dead battery. Check the battery voltage with the ignition off and then on. If the voltage drops signinificantly with the switch on that is a telltale. A dead battery can fool you with voltage but no amps.
Old 08-19-2010 | 01:03 PM
the 30 amp was blown.. was diff to find becasue it is under red connector.. thanks tho going into garage to find one.. any idea why it blew?? thanks guys
Old 08-19-2010 | 01:10 PM
only had a 25 amp fuse threw it in started.. then blew few seconds later..bike shut off.. going into town to get 30amps.. fu(k i hope its nothing serious.. i love this bike and i have limited funds..
Old 08-19-2010 | 01:11 PM
calitoz's Avatar
Escape Reality
Fuse usually do not blow without cause. Check for the cause...you wouldn't want to be left stranded.
Old 08-19-2010 | 01:18 PM
i know.. but where should i start if the 30 blows again.. any ideas? ive been reading and im not sure which direction to go.. starter/wiring/regulator/solenoid..
Old 08-19-2010 | 01:26 PM
thetophatflash's Avatar
Start at any aftermarket equipment installed. Bad connectors, worn insulation, etc.
Old 08-19-2010 | 01:36 PM
all stock except pipes galfer front and rear brakes. and undertail..
Old 08-19-2010 | 03:28 PM
Stevebis1's Avatar
Just pulled up the wiring diagram. If a 25 amp fuse blew something is wrong. Looks like you'll want to check the charging voltage - possible R/R issue. The main fuse fuses that and the +bat to the ignition switch.
Old 08-19-2010 | 04:34 PM
Syclone's Avatar
Boosted
R/R.
Old 08-19-2010 | 05:11 PM
Angry
Shi+....where can I find a cheap/used one?
Old 08-19-2010 | 06:50 PM
Syclone's Avatar
Boosted
Search:
https://www.superhawkforum.com/forum...earchid=640362
Read this:
https://www.superhawkforum.com/forum...maha+regulator
Decide whether you want:
OEM plug and play - Honda or Aftermarket
Yamaha / etc - cut and solder your harness
Shane702
07-26-2012 09:59 AM
supervee
07-08-2012 08:27 PM
aja
12-12-2011 01:19 PM
chadnol10
04-19-2011 08:36 PM
EngineNoO9
03-08-2006 07:25 AM
