929RR Front End Swap Question.
Ok. I just fnished my 929 front end swap, tightened everything up. Went for the first test ride. Shocks feel great and so do the brakes. The only thing that is stumping me is why the whole front end that slides into the frame is sliding maybe a a quarter to a half of an inch foward.. any ideas? Different size bearings? Thanksss
We figured it out. On the stock lower tripple and axle that goes through the frame( I dont know the proper name for it) there is a space that the top bearings sit on.. the stock has a groove that the spacer sits on..and the 929 one has the same groove.. except its a little lower. So Im making a spacer tonight and Ill let you know how it works tomorrow.
To me it sounds like your missing the race/cup that sits in the frame (there are 2, top and bottom).... any chance it fell out when you first removed the triple? Even with incorrect bearing/races, you shouldn't have anything close to 1/4" slop....
J.
J.
Yep that was it. Used the wrong race and it didnt move down far enough as I needed. Just switched them and it its PERFECT!! Brakes are WOW. And lost some turning radius. Thanksss
