190 tire question
Old 03-05-2011 | 02:41 PM
geekonamotorcycle's Avatar
190 tire question
Hello
I am in need of a tire for use in the short term. Will any modifications be needed to get a 190 size tire on my 2000 vtr?
Old 03-05-2011 | 03:05 PM
jay956's Avatar
Itll fit but its not ideal. being on a 5.5" rim causes the tire to be pinched resulting in a smaller contact patch at lean.
Old 03-05-2011 | 03:06 PM
ok, it will be a temporary measure. I want to be sure that I dont have to modify anything.
Old 03-05-2011 | 03:19 PM
saige's Avatar
the boss
even as temp tire.really try to stay with correct size.
Old 03-06-2011 | 06:54 AM
If you have a hugger mounted, it will probably rub on that, and potentially on the swingarm as well if the wheel is forward on the chain adjusters... This since "pinching it" like jay said will make it taller... Also, the speedo will be measurably off...
Old 03-06-2011 | 09:41 AM
Throw it on. I ran a 190 for a couple years. Makes the back end higher like a spacer would & makes overall gearing taller but is fine otherwise.
Old 03-07-2011 | 04:19 PM
JamieDaugherty's Avatar
+1 - I've done it too. Running a 190 tire is not a big deal, there are plenty of other things to focus your attention on!
Old 03-07-2011 | 04:37 PM
Well I changed my tire today and found yet another problem which was corrected
http://goecogreenmachines.com/2011/0...green-machine/
Old 03-07-2011 | 06:39 PM
nath981's Avatar
well, for what it's worth, the Q2 180x55 has the same approximate dimensions as a 190x50 BT0-16 when mounted on a 5.5 in rim. And some manufacturers have indicated that it's acceptable to mount 190s on 5.5 rims.
I didn't like the feel of the larger tire/profile after I got used to it, but couldn't tell any serious adverse affects.
Old 03-28-2011 | 11:55 PM
lucas_chanel's Avatar
From: currently stationed in La. but from the HOuston, Tx area and im home every weekend
lucas_chanel is on a distinguished road
Does any one have any comment on the new road attack 2 tires fron continental. looking for som new tires. currently have the BTO-15 and was referred the the BTO-16 but then was told about the Road attack 2. Any feed back
Old 03-29-2011 | 05:42 AM
uchi's Avatar
you can get 190 tires that are meant for a 5.5 inch rim. if its free use it and dont worry about it, itll change some things but wont make the bike un stable or anything like that. im going from a 170 to a 190 on my track bike, that should be fun
Old 03-29-2011 | 07:50 AM
I just got conti motion Z tires and they are nicer than my pilot activs and stickier than the diablos that were on this bike before.
whatthefnck
04-04-2013 05:56 PM
trinc
03-12-2008 07:14 AM
FordsnRebels
08-19-2006 08:58 PM
spacemonkey
04-23-2006 07:18 AM
GUARDIAN
07-16-2005 09:06 PM
