15T sprocket ?
Old 01-30-2008 | 12:19 PM
bigmike1219's Avatar
bigmike1219 is on a distinguished road
15T sprocket ?
Ok a new guy question, how hard is it to change the front sprocket?
I have a 520 kit I want to install, the back is not a problem and yes I do have a chain tool.
thanks
Old 01-30-2008 | 01:14 PM
Blue Ridge Boy's Avatar
Not hard at all.
Just unbolt the cover, take off the nut holding the sprocket tight (this nut may be very tight if you have never messed with it). Slide the sprocket off and slide the new one on and bolt everything back up.
Old 01-30-2008 | 01:24 PM
Thanks, my project for this weekend
Old 01-30-2008 | 01:27 PM
To just install the front sprocket?
It will only take you about 15-30 minutes as long as you keep all of your bolts organized, which by the way, pretty much all the bolts on the sprocket cover are different lengths, so label them so you are not lost latter on when you can't remember what went where.
Old 01-30-2008 | 08:33 PM
Thanks for the tip, I am installing the 520 kit 15/43
Old 01-30-2008 | 09:08 PM
Hotbrakes's Avatar
You're gonna love it!
Threading the chain around is the hardest part.
Old 01-31-2008 | 02:56 PM
Make sure you don't have the cover off for too long. The slave cylinder will work its way out and will draw air into the clutch master cylinder. This is a major pain in the *** to resolve. Also, use the rear brake to hold the output shaft steady as you loosen the countersprocket bolt.
LineArrayNut
10-05-2009 04:25 AM
reaper
10-19-2007 07:45 AM
duran
08-27-2007 08:57 AM
trickphoto
07-19-2005 06:55 PM
mrjakeanderson
05-21-2005 10:13 AM
