100 ml oil + in engine
Old 04-28-2009 | 12:05 PM
merlyn's Avatar
merlyn is on a distinguished road
hello !after I replace the oil filter and of course the engine oil...I put 4 l of oil instead of 3,9 It is there 100 ml a problem...?the oil level is 3mm upper than maximum level
Old 04-28-2009 | 12:27 PM
PUSHrod's Avatar
Might smoke some and blow a little into the airbox. Mae West might tell you that too much is always better than not enough.
Old 04-28-2009 | 12:44 PM
Little_Horse's Avatar
2nd mouse gets the cheese
on some motors over filling will run the risk of blowing out seals, but I don't think you have put in too much oil yet.
Old 04-28-2009 | 12:48 PM
merlyn's Avatar
thank you
Old 04-28-2009 | 03:34 PM
j shizzy wizzy's Avatar
mildly retarded
the line is there for a reason, no?
Old 04-28-2009 | 04:04 PM
swordfish's Avatar
I always put enough in so that the level was just below the top of the window itself. the bike goes through oil anyway. in a few rides it will be right where you want it.
Old 04-28-2009 | 04:39 PM
Overfilling the engine oil on any modern engine runs the risk of foaming the oil and causing engine damage. I don't know if the amount you overfilled is a problem, but I would drain some out...it's very easy.
Old 04-29-2009 | 09:01 AM
merlyn's Avatar
I m afraid to drain out some oil!but how in safe?
Old 04-29-2009 | 11:01 AM
JamieDaugherty's Avatar
I always dump an entire 4 quarts of oil into my bike. Never had any burning or smoking, no problems what so ever.
Old 04-29-2009 | 11:25 AM
killer5280's Avatar
That amount (100 ml) + or - won't affect anything.
Old 04-29-2009 | 11:37 AM
swordfish's Avatar
+1. that's exactly what I do. and usually, the level ends up right at the top of the window. I've done it this way every oil change for 5 seasons, and so far no issues.
Old 04-29-2009 | 11:40 AM
+1 I always put in 4 qrts, never had any issues
Old 04-29-2009 | 11:46 AM
But merlyn put in 4 LITERS. Fill during an oil and filter change is 3.9 liters or 4.1 US quarts, according to the Honda manual.
I dump in 4 quarts, start and run it for 5 minutes, then check the level after it has sat for 5 minutes. I then add carefully to the full mark...it takes about another 1/10 quart. You're fine with just 4 quarts, it's between the marks, but I'm kind of **** about the fill level during oil changes.
Old 04-29-2009 | 02:13 PM
merlyn's Avatar
ok thanks for answers
Old 04-29-2009 | 03:24 PM
pigwings's Avatar
pigwings
4 qts
Me too. *** the line.
bmwalfaone
01-12-2011 05:04 AM
denmah
09-10-2007 09:56 PM
nophr
10-18-2006 02:02 PM
EngineNoO9
06-29-2006 12:16 AM
ClevelandSuperhawkRumble
06-05-2005 10:58 AM
