damn you kickstand from hell!!!!
I learned recently while doing the brake swap, that when you remove the front axle, then the front wheel, with it on a bike stand, it will try to fall over. The shocks are allowed to move independently. My buddy caught it.
Sorry to hear that it fell.
I can one up you on that, back in 99 when i got mine i was so proud of her. i was scared someone would steal it out of our work garage so i put a wheel lock on her.
After work i was eager to ride, got on her fired her up and let the clutch out.
Next thing you know my steed is laying on the concrete floor still running and i am standing over her thinking, what the heck happened.
Well she didn't like that front wheel lock very much and when i pulled out and the lock hit the caliper that was all it took fo rme to dump he on the ground.
Busted turn signal, busted fairing, dented pipe and bent clutch lever.
Here is to your misery, been there, done that.
But hey, I'm the one who stepped off without putting the sidestand down.
I cut out an 1/4" thick 12" square piece of steel diamondplate with three 6" metal stakes welded to the bottom to anchor it in place. Works great, even on the soggy ground after the nasty rains we had here in MO this year.
Could put a D ring on it and use it as an anti-theft device too I imagine, it's heavy!
I feel your pain... I had the old VTR parked outside my old apartment complex (as usual) with the bike cover on it. In rolls a monster monsoon storm with extremely gust winds. the cover acted like a sail and pulled the bike over on the kickstand side. Bent clutch lever, dented tank, scuffed exhaust. Shitty
I thought the ground was going to be too soft to support the bike so I parked it on asphalt when I got to work. The sun came up and beat strongly on the earth below, including the patch of asphalt under the kickstand. Intending to run an errand at lunch I found the VTR on it's side with the foot of the kickstand six inches into the pavement. Slo-mo tip over so the damage was slight but it took three friends to extract the bike out of the surface of the parking lot.
Bandit400man
05-09-2012 04:47 PM
