Wont Start...please help
I rode to the movies yeterday and when I got back outside...it was pouring...1st time my HAWK has seen rain. It started & ran fine.
I rode it to work this morning...no rain...started & ran fine again. Went to go to lunch and it wont start & it just clicks when I try to start it. Got a jump start...runs fine...(ODOMETER works just fine)...(mileage & trip flickers)...(TACHOMETER goes off and on) if i pull the clutch in and rev it,...the TACH comes to life for a few seconds then back out again. Took the battery out & went to AutoZone...they tested it, and said its no longer a good battery.
1.) Could the rain have done something to cause this???
2.) Could it just be that batteries just go bad???
3.) Possibly something else???
Any input will be helpful.
Thank you in advance
2.) Yes.....how old is the battery?
3.) Yes.....regulator/rectifier is one of the common places to look for issues.
Rex
My bike ran into a similar situation. To test the solenoid etc. I actually just connected a jumper cable to the starter + terminal (on front of bike covered in black rubber nub) and TOUCHED (not connected) the other side of the jumper cable to the battery + terminal carefully. This method only uses one wire of the jumper cable. The starting action didn't change at all from what it was doing before so it wasn't a case of good battery bad solenoid. Be prepared to pull the jumper cable off the + terminal, it welds on a little. Also, I'm not responsible if you blow yourself up.
mcadena89
06-03-2009 01:04 AM
