Winter projects " what's every one doing
Old 11-23-2007 | 04:48 AM
  #31
FL02SupaHawk996's Avatar
Fastest Color
Good advice Stumpy, but how do you know if you need new CCTs? I listened to my top end closely and can't hear anything going on in there...perrrrs like a kitten....
Old 11-23-2007 | 08:57 AM
  #32
R1 Mirrors
I'd recommend R1 mirrors cuz they bolt right up and work great
I did not think they fit right (cocky angle compared to OEM) and the rubber boots did not fit right. So I grafted the R1 mirrors/stalks to the VTR fairing mounts with Don Herve's extenders in between, and life was good.
Attached Thumbnails Winter projects " what's every one doing-ba-98-vtr1kf-4-2-06-ft-c.jpg
Old 11-23-2007 | 09:37 AM
  #33
Jokers996's Avatar
Jokers996 is on a distinguished road
My winter project is looking like the VFR800 swingarm possibly 05 R1 sub frame and tail. Undertail exhaust. Possibly gonna be stretching swingarm 6 inches and and integrating a 300 back tire havent decided yet. A guy I know fabricates choppers and said he should be able to do that work for me in feb. Have decided though all I know is I am definately doing the swingarm conversion
  #34
Fastest Color
Sko, those look good! Not sure why mine were different cuz previous owner put them on and told me they bolted right up...I agree that the angle isn't the best and the boots aren't perfect, but I've been told they look and function better than OEM and that's gooddernuff for me
Old 11-23-2007 | 08:04 PM
  #35
GregW, I PM'd you with information on the solution to your 1000RR brake issue.
My projects:
VTR
Finish the 1000RR front end swap - install modded axle spacers and find some clip-ons that work (Duc 900SS Helis)
Weld a 900RR swingarm brace to the extra VTR swingarm. Clean up welds and powdercoat black. Install it and hope that the shock, exhaust, and hugger still work.
New front tire.
XS750
Fit up VTR front forks.
Strip bike to frame, sandblast everything, paint everything, and rebuild into a cafe racer. Big project. Long winter.
Old 11-25-2007 | 06:36 PM
  #36
Gregw's Avatar
Hi Greg,
Thanks for the PM, it’s been a busy weekend for me. I installed the 1000RR forks into the 954 triples today and got them squared up. I was able to mill off .033” from each axle spacer. I ran out of time so I wasn’t able to see how it fit with the wheel.
There was one thing strange that I noticed. With the forks parallel and the axle head flush with the outside of the fork, the axle bolt side is inset .160” from the outside edge of the fork. I have made a spacer to fill that in, just wanted to make sure I am not doing something wrong here.
Thanks for the tip on the caliper spacers, no one in town stocks them, so I’ll order them along with some other parts maybe this evening.
Old 11-25-2007 | 07:48 PM
  #37
I'm not sure but the set-back of the axle bolt may be correct and no spacer required.
Old 11-25-2007 | 08:05 PM
  #38
Gregw's Avatar
I went to the garage and snapped this. It just looks strange to me. Seems like the axle should be flush with the fork's outer edge.
Old 11-25-2007 | 08:08 PM
  #39
Mr Toad's Avatar
Deus vult!
Mr Toad is on a distinguished road
Not in any particular order or rush (it'll be 4 months before the bike's back on the road):
*CCT's
*fabricate exhaust hangers
*repair small cracks around the fairing mounts
*make a quick-change streetfighter mod with my extra headlight frame, bar-end mirrors and '85 Gixxer headlights.
Old 11-25-2007 | 08:17 PM
  #40
Check out the VTR set up, it is similar; although that looks more than .160".
The VTR oem set-back is about .1" but I'll have to check when I install my fork brace. I'm sure they want to be sure there is enough compression on the spacers with only about 30# torque on the bolt
Old 11-26-2007 | 09:15 PM
  #41
Gregw's Avatar
Hi Skokie,
Nothing wrong with your eyes, the axle is not really lined up in the shot since I removed the spacers to work on them. Thanks for letting me know about the stock setback. I haven’t had the Hawk very long and have only messed with the carb needles and exhaust so far. Looks like the CBR axle bolt gets a little more ummph with 58’lbs.
Old 11-27-2007 | 05:23 AM
  #42
Hotbrakes's Avatar
One project down: 2 Bros High Mount chop to 2/3 original length...just need to mount them up.
Next project: Begin fundraiser for new tires. Anybody interested in Kerker Carbon exhaust...only 2 months old?
Old 11-28-2007 | 07:44 PM
  #43
Greg,
I don't know the design clearance of the 1000RR forks. Since the bikes are put up and packed closely together in the shed it's not easily accomplished either. This is my take on it:
There should be some small amount that the forks will have to come in. It's designed into the bike, most likely for ease of wheel installation. BUT, the more the forks bend in, the more friction you'll have on bushings and seals (mainly bushings) and that leads to increased stiction which ultimately results in suspension action that is not as good as it could be. That is why I am still using stock width spacers. Granted 2mm isn't a lot but it's 2mm less that the forks have to bend.
Old 11-28-2007 | 08:29 PM
  #44
Gregw's Avatar
Thanks, I’ll take a look at that when I can bolt it together, Saturday or Sunday seems to be the earliest. I’ll check the center line and see if I bowed anything. Basically, I milled off the bevel on each spacer.
Old 11-28-2007 | 09:32 PM
  #45
RCVTR's Avatar
Talking
I'm putting an '02 RC51 in my garage!!!
My good friend Dean, who was just behind me when I crashed is selling me his PERFECT SP2.
I built an engine for it 3 years ago, with JE pistons and lots of head work.
It has an Ohlins shock, revalved forks, lots of cool bits. Also cmes with leathers, helmet and gloves.
Step 1 in my new track bike. My body floods with relief at the thought...
Old 01-02-2008 | 09:00 PM
  #46
jim2000VTR's Avatar
jim2000VTR is on a distinguished road
Smile this winter..
Above all, finding employment, as its been 14 long months and no pay. For some reason, I have purchased 3 motorcycles during that time, almost as many as I purchased while employed! Plus 2 cars too... hmm too much time to surf the Net?
I have to GET my 00 Superhawk, which I just left a deposit on. Then I am selling my '83 CX650e, the not-sold-in-the-USA version that is similar to a CX650 Turbo in looks, but not as fast. At least I have 3 interested parties, so that keeps the wife off my back.
Then on to check out the SH, change all fluids, tune up, new front tire, etc etc, plus finish my CX500 "adventure bike" with KLR front end as well as my second CX500 "restoration". And somewhere in there, I have to pull and rebuild the carbs in my '76 Goldwing so I can sell it in the Spring. Or Summer...
At times I wish winter was longer, as I'd get more of this stuff done!
Jim ("just so NO to projects!")
Old 01-04-2008 | 10:03 PM
  #47
vtrider's Avatar
roll through
vtrider is on a distinguished road
streetfighter,already have the LSL bar kit and vapor dash done. Just need to fab up something cool to cover the radiators and clean up the wiring. Unfortunately they decided to store all that wiring up front. I think I'll pull it all back under the airbox
Old 01-12-2008 | 02:00 PM
  #48
autoteach's Avatar
Here is one pic, sorry for talking so long
Old 01-12-2008 | 02:01 PM
  #49
autoteach's Avatar
i don't know if this is working
Old 03-17-2008 | 05:54 PM
  #50
Hotbrakes's Avatar
Winter is OVER! Lets see 'em!
Original goal- chop 2 Bros pipes
After unexpected collision on a beautiful 75 degree January day-
Paint job
Grips
Bar ends
Rim stripes
Daytona steering stabilizer
Lower fairing (tomorrows project)
Silverstar headlight (cause I dropped the other one trying to put the fairings on)
LED taillight
Camera mount on tank
So here it is, still working on the other tail section which is going to be black. The new lower is truck bed liner.
http://s33.photobucket.com/albums/d7...nt=NEWVTR4.jpg
http://s33.photobucket.com/albums/d7...NEWVTRSIDE.jpg
http://s33.photobucket.com/albums/d7...EWVTRCLOSE.jpg
Old 03-17-2008 | 05:56 PM
  #51
Jeepingoose's Avatar
Jeepingoose is on a distinguished road
Originally Posted by C5aig
What is this winter thing you speak of?
Ya, what he said.... whats "winter"?
You mean that slightly cooler, rainier time of year that usually lasts about a month?
Old 03-17-2008 | 06:15 PM
  #52
Stumpy's Avatar
Move to Wisconsin and you can find out for yourself!!!!!!
Old 03-17-2008 | 07:47 PM
  #53
haha uh.... i wouldnt mind, since I got my jeep and LOVE to wheel in the snow... but theres not a LOT of Coast Guard up there... a little but not much.
thedeatons
02-11-2015 11:04 PM
HondaJim
01-25-2009 08:39 AM
Dan Cronin
09-23-2008 05:42 PM
vasaq
05-09-2008 06:21 PM
Dave Wicks
02-24-2007 06:13 PM
Quick Reply: Winter projects " what's every one doing
