Stainless brake line layout
Getting ready to buy a set of stainless lines - most likely HEL and now I have to decide between 2 line (full), 2 line over the wheel, or 3 line (OEM).
I just searched the threads and could not find a specific comparison of the three. I don't race. Bought a set of VFR clipons, so I need to do something. I would like a touch better brake feel and a touch of bling. Seems to me two lines and a long banjo bolt out of the MC might look a bit odd. 3 line or 2 line over the wheel would solve this. And 2 line is cheaper.
So, does it matter? Is "over the wheel" visible? Why do some race regs ban this style (unless OEM)? I think this is what I am leaning towards. Comments?
They all fit pretty much the same. It's the level of "bling" that makes a difference, and color options. If you're doing lines then you may as well invest the other $50 and get good pads while you're at it.
In any case hadn't considered posibility of bubbles. I'll factor this in and let you know what I do.
If you really want responsive brakes get a couple more boxes ordered with radial MC
http://cgi.ebay.com/ebaymotors/Parts...1%7C240%3A1318
Good choice to get s/s lines. Go with the two separate lines versus the OEM. I purchased HEL about a year and a half ago through the local shop out of Florida, but I believe they had a falling out and now you have to get them through the U.K.
Before you buy I can send you pictures of my setup to give you an idea of what it will look like.
Yeah and I just saw you paid next to NOTHING for them! I am now thinking I will go dual line both from the MC. Seems to be the way most are recommending. Looks like I will also have to measure closely. I will be puting on VFR clipons so I will need an additional inch or so.
crazybrit
09-14-2007 08:52 PM
