Sprocket Questions asked again...help needed
#31
I took the easy route and went -1 on front, equals more than +2 in rear and I can't imagine going the extra +2... I've never topped out my S'Hawk, but do feel a noticable difference in sportiness, also vibes at my cruise speed of 80-90 cost me $12 for a 15 front, stock chain size and a noticeable improvement.
#32
i've got a top speed run venue that i've held her open to redline in 5th and shifted to 6th and it still pulls; the bmw k1200rs was dropping ever so slowly behind at this point past the 3 lengths i pulled from roll-on 90ish in 4th...this spot is miles long straight with a drag strip like profile... i think that it pulls 'better' in 6th for me, winding it past redline in 5th seems to lose momentum - i've never seen the rev limiter work on mine but i rarely shift higher than 9k...
#33
Red line in 5th is 150 mph on stock bike.
Top speed is usually reported as 155 mph. Maybe that's over revving in 5th, maybe not.
Bike won't pull red line in 6th, but if it pulled power peak (8750 rpm) it would be going guess what? 155 mph.
#34
I'm a aerodynamically challanged 6'4" and I found the stock gearing was defiantly to tall for me, I've just gone up to 43 on the rear and its way better. It lifts the front in first beautifully and when riding out on the roads i never have to drop through the clunky 2nd to 1st change for hairpins etc. In top on a bumpy side road i pulled a gps correct 147mph (showing 160+ on the clocks) with still a thousand rpm or so to go. I'm touring Scotland in a month or so its staying 16/43 but after that i'm considering the drop the front to 15 also.
#35
Well, hate to do this, but if you search for sprockets, somewhere in this mass of collected intelligence concerning our beloved Superhawk, you will find a spreadsheet with a comparison of gearing and top speed
You'll also find multiple mentions of the fact that with STOCK gearing, you can not hit redline on the bike in 6th but can hit max speed in 5th, so making the gearing higher will NOT give you a greater top speed. The Superhawk is what it is.
#36
I went 15-44 and love it. Also, being a fan of reducing unsprung spinning weight for many benefits I won't mention here, the 520 conversion is nothing short of great if you have the money to do it right. That means: buy good sprockets, e.g., AFAM high tensil alum, Supersprox, etc., buy a good chain, e.g., DID, Regina Gold, buy a chain breaker/rivet tool because you'll need it to cut and connect your new chain, Cut the chain as short as possible to move the rear wheel forward as possible to reduce your wheelbase a bit. Check your wheel bearings when you have it apart.
great mod which doesn't reduce fuel consumption unless your a tourer, and it does reduce shifting in the twisties allowing more attention for other critical concerns.
You can spend 300+ for parts and tools.
#38
It would be very close, but bear in mind, with a 16 tooth front and 45 tooth rear you will need a new, longer chain. That will cost a bunch more than 2 sprockets.
#39
Hi all, I'm going to do the 520 sprockets conversion but I'm a bit lost.
I want more low end ummph and am thinking about just increasing the rear sprockets teeth to 43, i think the standard one is 41.
If anyone can answer my questions I'd be gratefully,
1. How much top end will i approx lose if I add 2 more teeth on the rear.
2.would loosing one on the front and add two on the rear kill my top end?
3.Where can i buy these sprockets?? I'm not keen on ebay ones, is there a blade sprockets or something that people use. I have no idea how to source anything other than standard ones.
4. Is aluminum to weak for v twins? would steel be better?
I just want to increase to low end a bit so its easier to pull up with out compromising my top end to much, I want it all i know lol
Any help on this would be gratefully received, Recently gone back to a VTR after a 954 Blade, not as much fun, v twins rule. got loads of mods to do over the next few weeks.
Lisa.
Lisa.
HOPE THIS HELPS, I HAVE FOUND IT SHOULD ANSWER YOUR QUESTION THOUGH.
http://www.gearingcommander.com/
#40
how far back is your axle sitting in your swingarm? if it's back quite a bit now, you probably could sneak a 43 or 44 in there. Losen your axle nuts and see how far you can slide it up with everyhting in place, see how much slack you have by pulling your chain up and away from the sprocket.
usmc7051
10-13-2011 05:18 PM
BiggDaddyKool
02-06-2008 07:50 PM
duran
08-27-2007 07:57 AM
