some pics of my project.
Old 07-01-2007 | 10:30 PM
meangreen79's Avatar
meangreen79 is on a distinguished road
Attachment 3433
Attachment 3434
Attachment 3435
Attachment 3436
Attachment 3437
Old 07-01-2007 | 11:18 PM
superbling's Avatar
Looking yummy!
Old 07-01-2007 | 11:20 PM
Firehawk_ordie's Avatar
Firehawk_ordie is on a distinguished road
loks good, does that swing arm increse the wheel base? it looks really long, but it could be cause the sub-frame is off. did you have to fab brackets for the lower/upper shock mount?
anyway keep posting pictures.
Old 07-02-2007 | 08:13 AM
Lookin' Good, Green!
Old 07-02-2007 | 11:58 AM
project
Yes I had to make the plates. I will measure the distance between the axels and see how much difference there is.
Old 07-02-2007 | 01:52 PM
RacerX's Avatar
RacerX is on a distinguished road
Please forgive my ignorance but what it the swing arm from?
BTW - Look Cool As Sh*t
Old 07-02-2007 | 02:56 PM
calitoz's Avatar
Escape Reality
Honda VFR 800
and you need to make this shock linkage plate, move the shock along with re-routing the exhaust
Old 07-04-2007 | 04:48 PM
Alan's Avatar
Alan is on a distinguished road
Looking good there Eric what exhaust setup are you going for???
Old 07-04-2007 | 07:44 PM
project
I had the measurement for the bike but forgot it.the bike is at my dads house.I will try o write it down next time. I would like to find some new cans cheap of course since I will have to make the exhaust from scratch
Old 07-05-2007 | 07:10 PM
project.
The measurement from the center of the front axel to the center of the rear axel is 57 3/16. what is a stock bike.
Old 07-05-2007 | 07:14 PM
Hammer7205's Avatar
Hammer7205 is on a distinguished road
Green - I love the single sided swing arm....
Old 07-05-2007 | 08:14 PM
I believe the specs are 56.3"
Old 07-06-2007 | 05:41 AM
Alan's Avatar
It adds about 50mm onto the wheelbase
Old 07-06-2007 | 01:59 PM
alan
Alan I was wondering which port do I use for the rear brake. I am going to have a custom braided line made And i would like to know which one to go to.
Old 07-07-2007 | 06:24 AM
Alan's Avatar
Hi Eric
block the middle banjo bolt hole off and use the other, i fed my brake hose through the swingarm where the master cylinder is and out the hole underneath the swingarm it gives a much cleaner look.
this was a tip from Daz Sear another sss convert. heres what you should end up with this is a pic of Daz,s
Old 07-11-2007 | 02:15 AM
pics
Thanks Alan. One more question for now.Which suzuki clip ons work for this swap .do I need to have some custom spacers made. the top tripple clamps have that weird bend to them so that I can mount some superbike bars. thanks again for all the info.
Old 07-11-2007 | 09:53 AM
Alan's Avatar
Hi Eric
not sure about Suzy clipons i used Spondon clipons with about 2.5 to 3 inch rise to clear the fairings,or theres always Heli bars but i dont like them myself.
You say superbike bars do mean something like Renthal bars???? with risers.
Old 07-11-2007 | 11:41 AM
I recommend a rubber grommet in that hole to prevent wear from vibration.
Old 07-11-2007 | 12:58 PM
westcoast's Avatar
westcoast is on a distinguished road
Other than making the shock base plate and making ur own header, anything else have to be done to bolt on the VFR swing arm?
Old 07-11-2007 | 01:05 PM
westcoast's Avatar
And also, how much would 50mm more on the wheel base affect the handling? Or would a mortal like me even notice? Also, one more thing. What about the weight difference from stock rear to the VFR unit with wheel?
Old 07-11-2007 | 05:17 PM
Alan's Avatar
Westcoast you have to drill a new mounting hole for the shock in the frame,use a vtr swingarm bush on the left side and a vfr bush on the right or vice versa cant exactly remember now but this is vital you do it right because this determines where you drill the frame for the shock and for both wheels to be inline ( well i say inline but you will still need a spacer to line the rear sprocket to the front sprocket) i used a standard sprocket cut the teeth off machined down to about 5mm and use this as the spacer behind your front sprocket.
As for the 50mm i dont notice the difference cos hey i'm not Rossi lol but since my front end swap and swingarm swap my vtr is transformed it handles fantastic.
Weight wise the vfr swinger with hub/carrier does weigh some compared to standard but again will you or i notice???? i dont think so.
Old 07-11-2007 | 11:15 PM
bike
Thats good news to know. I am leaving for germany ( Munich) does anyone know of a shop ther where I cold get these bars. I was also thinking of using the renthal bars too.
Old 10-08-2007 | 01:46 AM
Bike
I am back guys. I will start working on my project as soon as my bicep repair heals.
Old 10-08-2007 | 02:01 AM
Scumbag's Avatar
Scumbag is an unknown quantity at this point
SWEEETTTTTT!!!
good to have ya back
Old 11-22-2007 | 11:37 AM
forks
has anyone used the spiegler upper tripple clamp conversion. I am thinking of buying it. it comes with bars and lines if I read it right. I got hte front end all together but can't remember if I used the 929 upper or 954 upper. which one should I purchase. is there a difference. I put it together with the 1000 front end but just can't remember which one.
Old 11-22-2007 | 10:19 PM
Besucher98's Avatar
Besucher98
I kind of wondered too if any one has any input about the spiegler upper tripple clamp conversion. Anyone????
Twitch78
09-05-2012 10:40 PM
uchi
09-13-2010 06:31 PM
DGR Fab
01-21-2009 11:53 PM
joshn569
02-17-2007 10:04 PM
EngineNoO9
12-04-2006 05:27 PM
