replacing valve stems
Old 09-05-2011 | 05:47 PM
20_rc51_00's Avatar
With the tire swap coming up I am also going to replace the valve stems. I was intending to replace them with some thing more permanent and reliable... ie not the OE rubber ones. Any recommendations? specific size? Alum vs steel? Those that tighten from the inside vs outside?
Thanks
Old 09-05-2011 | 09:56 PM
What's wrong with rubber valve stems? I've had new aluminum valve stems leak... but I've never had that happen with a new rubber valve stem
Old 09-05-2011 | 11:01 PM
msethhunter's Avatar
The ones that get tightened in are now where near as reliable as a good old fashioned rubber one. They tend to losen up and leak at the worst possible time, like on a long ride in the middle of nowhere. Stick with whats known to work.
Old 09-06-2011 | 07:28 AM
cliby's Avatar
I have had similar experience. I would use the shortest rubber stem that allows good access for air. And replace them at each tire change. The longer, heavier (metal), or right angled ones, for me at least have not been a positive. I don't know if its the heavier weight and all the forces on the stem over time that promote flexing and loosening, but it seems to happen.
Old 09-06-2011 | 07:36 AM
I installed some of the snazzy angled aluminum Ariete ones from Kurvey Girl....
nnjhawk02
04-29-2013 08:33 AM
7moore7
11-11-2010 04:47 PM
jkrswld
02-26-2009 03:03 PM
mikstr
05-03-2007 06:38 PM
Otto Man
01-06-2007 02:36 PM
