RC51 swingarm Mod.
#91
Yep that is the idea, aslong as my measurements are all correct, other wise it will be an expensive paper weight ha ha
The hole dimentions are from Tweety, and used the same dims for his conversion, but you have to use a ride hight adjustable shock for it,(mine has an ohlins which is) i dont think the standard showa shock has that facility?
I also have an Ohlins rear shock. Are they all adjustable or are there different types of Ohlins shock that have the height adjustability as an option when new?
#92
Gaggenau, Hi nice work. I also would be interested in one of those linkages. Let me know if you would be thinking of maybe selling them, if so how much ? have you thought about having more than one made ?
#95
The only reason im having one made to start with is, that i dont want to start getting bits machined to send off to you lot who want one, and then find out that its flawed in one way that could end up bad
Thers realy only one pic left then that the whole peice done, nothing else to see lmao.....
#96
Just got me doubting myself, i better go check tomorrow if it is adjustable
#97
#98
Back to square one, now gotta figure out how to make it ride height adjustable
#99
Good call on the linkage.. let us know how it all works out.
#100
I'll save you a lot of trouble... Don't change the link you have made... Adjusting that geometry doesn't get you what you want... It only changes the leverage the shock has ie it changes essentially how hard a spring you want... Get a height adjustable shock or make an adjuster for the one you got instead...
#101
Yeah they stopped offering the ride height adjustability a while ago. I haven't found an answer yet if you can get it changed. I will be at Dan Kyles shop in the next week or so and will ask then if the adjuster can be retro fitted to the shock.
#102
I was thinking about chainging the clevis mount at the top of the shock, i doubt you can make it any shorter, but at least a new one you can make longer to suit?
What was youre solution to this tweety? jsut having a read through the posts it seems as though you didnt opt for an adjustable shock?
#103
That sounds good, post up when you know that would be awsome.
#104
I could be wrong though and the adjustment is on the other side.. Either way it was a large bolt.
#105
I have CBR F4i shock that Jamie Daugherty worked over for me... But instead of having him lengthen it to suit a stock VTR I left it stock lenght and made my own adjustable top clevis... Since it's shorter than the stock fork I can adjust it some +- 15 mm or so... More + if I swap to a longer bolt...
And yes, essentially it's a beefier bolt through the frame with a double nyloc-nut on either side, loosen the nuts and move up or down along the lt and then tighten it down... Simple and effective...
http://iloapp.tweety.se/gallery/images?Album&album=53
#106
You sir are quite correct...
The Storm uses a 10mm for the bolt peice, and the SP2 uses a 16mm for the same
Lets see what i can knock up at work out of stainless
On your's tweety, did you thread it so that the bolt head was inside the "u" peice? and then liky you said thread the threaded part through the frame and bouble nuts either side?
#108
Thats exactly the way i was thinking about on the way back from the gym
mr.billet
06-20-2010 07:42 AM
