RC51/ SP1 conv
RC51/ SP1 conv
Hi guys
Thought this place would be best to answer my question
For the guys that have done the RC51 f/end swap,how much
Of a advantage is this swap compared to a hawk f/end that has
Heavier springs,f/brace and steering dampner,
Reason is ,I am in the process in doing this mod
And I dont want to waste time and money for the same result
Any feedback would be appreciated
cheers
cheers
I'm sure you'll get different opinions, but I can tell you two very easy upgrades that make a huge difference. I was toying with the idea of doing the RC51 swap, but instead I installed Race Tech springs and a fork brace and that alone improves handling and braking enormously. No more front end dive, more stable, and still has a compliant ride. I highly recommend just the spring and brace mod. Gold valves are certainly bound to make an improvement, but what I did was a grand total of $200. RC51 swaps can get pricey and even the Gold Valves will add a couple of hundred by the time all is said and done. Depends on how much your wife will let you get away with. Cheers, Chuck.
I did both. In that I have 2 hawks & one on each. My daily rider has the race tech springs and heavier oil. Huge improvement over stock which to me was unrideable.
My "nicer" hawk (no rain, tons of mods) I did the CBR1000rr forks. It is another huge step ahead. BUT yeah way more dollars.
If you have stock now, and have more brains than money, do the springs first.
In the long run though, I want the cbr forks on my daily bike too. (although I really could just swap them)
I'd say the main difference is rigidity... The stock forks with springs and goldvalves are fairly a decent suspension really... But even with a brace in place, they twist and turn... If you are really lightweigth, less than 70Kg, then it's not an issue, but for me at 90+ Kg, I couldn'tmake them stop moving in places I didn't like...
The crop of USD forks, including the RC/SP forks have more adjustability, and is more rigid by far, since the triples and outer tubes form a unit...
But yeah, it's spendy... Especially is you opt to use RC/SP parts, since they are becoming more rare... CBR 1000RR parts are more commonplace...
Thanks guys really appreciate the feedback,my bike has the heavier springs f/brace and scotts steering dampner.
But also have a complete rc51 /sp1 f/end,
Just didnt want to go to all the hard work installing the rc51 f/end for the same result,you guys have just made my mind up.
cheers
cheers
huge difference. and like said if you already have the parts.........
I will say without some work on the rear shock its really out of balance and hard to feel all the improvement. the rear stock shock is not good and very harsh.
cheers
In OZ nooo.So coming from the uk.Had to make a new spacer for front axle,
SP1 upper so fairing has to be trimmed.
And awaiting for the apex risers to arrive.
Its just like having sex slow and patient
