RC51 coils
Old 01-17-2006 | 03:07 AM
Texassuperhawk's Avatar
Texassuperhawk
RC51 coils
I got my eye on some rc51 coils and since I'm already in the Shawk doin a bit of work, Does anyone know if they are compatible with the superhawk and if they may be any better?
Old 01-17-2006 | 10:58 AM
Speed_Demon's Avatar
If the primary resistance (ohm's between two input wires) is within .1ohm of the hawk's they should be fine to use. I think the hawk's are around .7ohm. Don't know if they put out more though.
Old 01-17-2006 | 12:28 PM
superbling's Avatar
I wouldn't see why they would be any "better" but two things I'd check are: the sparkplug connector length and the wiring harness connectors on the coil end may be different since the 51 is fuel-infected (just a guess).
Old 01-17-2006 | 05:07 PM
Yeah, I don't think the RC51 coil would be much better. The only reason I can think they would be is because the RC51 has more compression requiring more juice to create a spark under compression.
On my 1980 KZ1300 the stock coils really sucked so I installed some late model GM coils with .7ohm resistance and a 1.8ohm ballast resistor for a 2.5ohm total primary resistance. They work great even if I gap the plugs to .045". I wouldn't get your heart set on the RC51 units but keep an open mind to higher output coils.
Tweety
01-25-2011 06:25 PM
dickard37
06-08-2010 05:33 PM
Gregw
03-12-2010 12:15 PM
call me phil
05-25-2007 04:57 AM
thump
08-14-2004 08:23 PM
