More torque required
Old 08-03-2011 | 09:14 AM
davwas's Avatar
davwas is on a distinguished road
Hi all
I run a FireStorm in a Power-to Weight restricted class, here in the UK.
I am bang on the P-to-W (carrying 4lb of lead), but could benifit from more torque!
I have seen various posts re 2 into 1 exhausts, most saying it will up the torque, some saying it will be worse... Any thoughts ???
What about cams?
Any advice will be appreciated
Dave
Old 08-03-2011 | 09:25 AM
superhen's Avatar
You do know that torque and horsepower and directly related, so if you go messing around to find 5 more ft-lb of torque, you will inevitably change your horsepower. For sure you're going to need some dyno time for this. And someone with quite a bit of tuning/building experience, not some fly by night shop who wants you to but a new exhaust and charge you for a dyno run. Probably your best bet would be to change gearing if you haven't already.
Old 08-03-2011 | 09:50 AM
comedo's Avatar
Try Roger Ditchburn at Revolution Racing
Old 08-03-2011 | 10:42 AM
killer5280's Avatar
Ditchfield.
Old 08-03-2011 | 11:01 AM
RCVTR's Avatar
+1 for changing the final drive gearing.
+2 for contacting Roger D.
Old 08-03-2011 | 11:38 AM
zmaniv's Avatar
I thought I heard the longer length tubes on the high mount exhaust gave you a bit more torque while dropping the HP. Dont quote me just seems to stick in my head
Old 08-04-2011 | 12:08 AM
davwas's Avatar
Hi
Thanks for the tip about Roger
Re Gearing: Yes, I change the gearing to suit each track.
I also understand that HP & Torque are directly related; but having done a bit of looking around, wondered if anyone had some definatve tips?
For instance:
Would a set of 2 into 1 exhausts maybe lose 4 hp, but retain the same torque? That would be good for me, as I could take off some lead!
Would fitting high-lift cams gain too much power and not much torque?
Cheers
Old 08-04-2011 | 11:55 AM
RCVTR's Avatar
Increasing the duration on the cams will generally move the meat of the torque curve to a higher rpm range - thus producing more power.
High compression pistons should give you a bit more torque everywhere.
Light wheels have lower moment of inertia, which would gain you more acceleration than you would lose by adding more ballast to compensate for the weight reduction. Lower inertia is equivalent to more torque.
ginja1001
02-16-2015 09:22 AM
benny hedges
04-06-2010 07:16 PM
captainchaos
06-04-2007 01:39 PM
oicdn
01-16-2006 10:48 PM
EngineNoO9
11-10-2005 11:18 PM
