jet kit (yeah yeah I've searched)
I want to double check before I go ahead and buy a kit. My bike currently has some unknown size jets that seem to be making the bike run rich (I was told it had a "stage 3" jet kit). So I want to buy a kit to get my carbs tuned right which I've never had before. I have a K&N, erion exhaust, and pair block offs. Is the dynojet kit the one to go with or the factory pro? or is there a difference?
Hard to nail this one down. I can tell you that I am running a DJ kit on my VTR (Microns, modded stock air filter) and it is spot-on. I had it installed adn dyno-tuned mind you but the results are 100% statisfactory. I am sure, however, that some will give the same report for the Factory kit.
Good luck
Mikstr
Good luck
Mikstr
yeah but the jet kit can be installed without the rest. all I know is whatever is in there now is dumping lots of fuel in and under 4k it sucks pretty much. there's no airbox mods, I did the pair valve delete on my own. and the k&N was there when I bought it. I believe the jets were on from the original owner (I'm the third owner)
SpeedieGTI
10-22-2013 07:38 AM
Red_Liner740
07-20-2008 12:51 AM
