Increase compression ratio
Old 04-21-2005 | 09:39 AM
EMetz996's Avatar
EMetz996
Has anyone machined their heads down as little as .010 to increase the compression ratio?
The VTR's are on the low side around 9.6, and .010 to .020 machined off the mating surface would bump it a little. I've done this to large bore ATV's with great success, but never a motorcycle.
Old 04-21-2005 | 10:10 PM
RymerC's Avatar
RymerC
I'm curious as to whether we could just use a thinner head gasket?
Old 04-22-2005 | 07:55 AM
EMetz996's Avatar
EMetz996
Re: Increase compression ratio
Generally speaking, as of the last 10 years or so I have not seen a head gasket thinner than .020 except on Briggs motors. So going thinner isnt an option today on most engines, but it used to be!
Old 04-22-2005 | 11:04 AM
RymerC's Avatar
RymerC
is that what the stock gasket is? thanks honda!
looks like milling is the only alternative to pistons... Unless you want to play with cam timing
barncat
08-20-2012 08:46 AM
Little_Horse
02-14-2012 04:32 PM
Karbon
10-07-2009 08:04 PM
Red_Liner740
08-18-2009 06:51 PM
mikstr
05-06-2006 05:02 AM
