how can you get more top end on the Hawk???
Old 08-08-2005 | 05:30 PM
bluesman's Avatar
bluesman
Re: how can you get more top end on the Hawk???
Don't know if it will be of any help - not really what you been looking for...just my personal findings regarding coping with other bikes in hot ride...
I moved to SHawk after 5 years on inline-4s (before that I had smaller twin and opposite, and some light 4s etc.), and my 4-line buddies pulling away from me etc.
Then I went for properly big (1 week) rideout through proper empty mountain roads and for 2 days I've been struggling. I just could not crack it. I realized I did not know how to ride Shawk - same curves I "burned" on my previous inline-4 600 I can't get any decent speed through, and engine seem to be revving lazy etc. etc. And then, on day 3 I found myself pulling away from my buddies. Simply because I took advice of crazy french supermotard rider we rode with. BTW - he rode old - first edition - VFR750F, and been esily pulling away through twisties from things like 1995 FZR1000 with all it's 145 bhp.
That's what he said "It's like monocylinder. Just stop flying into the turn at excessive speed, late braking and all that. You got twin: enter turn at reasonable speed, do not be concerned with other guys falling in faster. Then get you line (in your head), drop bike onto trajectory and just keep on opening throttle from very beginning, as soon as bike is tilted. When it will start to loose rear -and because it is twin ith it's "power pulses", just like ABS - you will feell it before it will actually lose rear to unrecoverable level, it will first TRY to loose it - stop twisting grip and wait for a bit closer to ext from turn and just twist it further. You will find that you not only catched your buddies, but have way more exit speed!"
I know it might be a bad advice, it's just worked for me, thou it is all so individual...
And - I found extra power punch at 6500 rpm - my bike has stock jetting and filter, just open exhaust...well, and proper aftermarket shock and reworked forks.
Anyway - I am learning to ride again after that advice, and it works so far...against newer inline-4s. I am still a bit bad at right turns but almost done it in "lefts"....
Old 08-09-2005 | 08:34 AM
roadrun_fr's Avatar
roadrun_fr
Aprilia RSV 1000 has a lot more top end I can tell you ....
And for a relative decent price ;-)
Old 08-09-2005 | 10:23 AM
bluesman's Avatar
bluesman
IMHO rc51 is a brilliant track bike, it is actually meant for track at first place...and when you have spare money you can spend it on HRC kit for it and smoke it really hard.
RSV got more top end too, but as for track handling - it's no match to RC51...and it's bigger.
But as good as both bikes are for track as bad they both are of real life, daily rides.
RC51 IMHO very uncomfortable, Mille by not a tourer too and a bit nasty to handle.
And suprisingly for me - when I tried those bikes both seemed to have less low and midrange than SHawk....something I can't quite explain for RC51 and for Mille...can explain only by 60 degrees cylinders in Mille vs. 90 degrees in SHawk.
But honestly - if I'd have more money I'd gone for Aprillia Tuono R. Just cos love brutal and naked bikes...
Still, if you are serious - talk to Revolution Racing in UK. Those guys worked with Moriwaki on BSB SHawks.
Up to 150 bhp at rear wheel with sorted suspension - killer machines...mid-level they do 120-130 bhp and fully street rideable with normal reliability.
Old 08-09-2005 | 10:35 AM
bluesman's Avatar
bluesman
well, everybody have his own preferences - this is why motorcyclists are so interesting people - diversity is a key!
You see - I am all about sport-turing, but with no highways..
Since you mentioned supersports.... :wink:
I saw how it is with CBR/GSXR/R1/ZX10 guys when you have to cover at least 600 km per day and not on highways....mountain passes 1 car wide...gravel on crossings between proper roads and backroads...bumps and holes...roadworks...
And all this in mix with high-speed twisties.
It was really funny to see - in the morning all supersports been burning curves, leaving me for good.
Midday - supersports tired, to tired to push it and I, my buddy and guy on Africa Twin still am in same mode...even in curves - same pace as before.
Evening - all down to real-life speeds, all at same pace with supersports slightly behind...
At the end me and my buddy went for walk to lake and to take some cool photos. Supersport guys they went for laydown exchanging opinions about how shitty roads been, how their back hurts, how they can not sit anymore because of sore bums....
And guy on Africa Twin went for a ride to top of mountain!!!
Imagine it on track - all other way round, I'd probably go for laydown to complain about wobbly knees and they would go for a ride...
Old 11-19-2005 | 04:29 PM
swordfish's Avatar
Originally Posted by luiggispeed";p=&quot
Hi,new member here.
Got a 02 SH for track only,I need more top en as Im being passed by almost everyone,mine would do 145 at best,bone stock.I ordered a 43 tooth rear sprocket,thinking I will be able to stick up the 6th gear.as I wasnt using it on a 1/2 mile stretch.I have no trouble on the corners at all,mine has SS braided brake lines,HH pads,GP208 tires and thats about it.
I'm kinda surpprised that you couldn't go any faster. was it a distance issue? not enough runway? cause I hit 135 at about 8,000rpm in 5th. and no, this wasn't a faulty speedo issue since my buddy on his 04, R1 was there to confirm. he actually thought we were going a little faster. I wasn't really paying attention since I knew my speedo was way off at those speeds anyway. he was infront of me but not pulling away, and he was reading 140. but anyway I still had an whole gear left. I still haven't touched 6th at speed. as far as I know, my gearing is stock. I was under the impression that the SH would flirt with 160 at the extreme end, and my speeds were about right for that. I did have a jet kit, but stock pipes. just wondering.
Old 11-19-2005 | 06:02 PM
bluesman's Avatar
bluesman
Are we talking real speed or speedo? If all above was about speedo indications - sorry, I'll take my word back. Real speed I got out of my SHawk was something like 143 Mph I think - that what GPS did show me (I am converting KMph to Mph, hopefully correctly).
Speedo was WAY more than that. I have standard gearing, 1997 model of SHawk, thou been bought from first owner in 2003 with only 38000 km on clock (kinda 24000 miles?)
All speedos lying like hell. Digital, analogue, new, old - all bike speedos are WAY off. Verfied on many different bikes with bike computers, GPSs and other toys...Speedo can EASILY show 155 at 145 real.
But - an GSXR or Blade will leave SHawk AND RC51 in dust if rider equal, don't kid yourself.
Old 11-19-2005 | 11:35 PM
superhawk22's Avatar
Apples and oranges again. I4's will always be able to pass you in the straights that's what they're made for. It's the same thing every time I go to the track. They pump thier chests in the straights only to watch my fat *** go by in the corners.
Old 11-19-2005 | 11:38 PM
Apples and oranges again. I4s will always be able to pass you in the straights that's what they're made for. Same thing happens to me every time I go to the track. They pump thier chests in the straights just to watch my fat *** pass them in the corners.
Old 11-20-2005 | 12:27 AM
swordfish's Avatar
no arguement there, but in the reviews I've read, gixxer 1K's will do anywhere between 170-to 185, so the 160 for a SH still sounded feesable. just going by what I've read. I just read an article in a british sportbike mag the other day that commented on the superhawk topping out around 160. the article was drawing a comparrison between the hawk and the RC51. and how the RC could still top 170. I dunno, I know that there are alot of varying opinions about how fast these bikes go, and I know that it really doesn't matter since we hardly ever go that fast. either way, its damn fast. I know that an R1 will have less error on its speedo than the notoriously off speedo of the SH. that's why I didn't bother paying attention to it. my point was, if the R1 was saying 140, even if it was 10 mph off, that makes it 130. but nevertheless, I was still only in 5th gear, and not even topped out in 5th. she had plenty more. I don't see any reason why it wouldn't have passed 145.
Old 11-20-2005 | 12:30 AM
swordfish's Avatar
Old 11-20-2005 | 10:46 AM
I know with stock gearing I've hit an indicated 160. 3 am on the florida turnpike and I don't think it had much more than that.
Old 11-25-2005 | 09:57 AM
mikecronis's Avatar
mikecronis
Thinner oils help top end I've found, by about 10%. I've heard of guys using a zero-weight on the track. Worth a try. (note* oils for serious track days are changed quite regularly.)
Old 11-30-2005 | 07:16 PM
Turbodgixxer's Avatar
Turbodgixxer
I have a Veypor2 that I switch from my hawk to my gsxr track bike. I'll tell you right off the bat, at an indicated 70 with just a 1 up rear sprocket, I was only going 58! 1 up rear won't throw it off that far, so the factory speedo is way to far off. The top I had my hawk up to was recorded as 152, but I coming up onto a pack of cars. So, from judging by that, I would say it should top off at 160ish.. I have TBR full system, advancer, factory Ti jet kit, BMC filter, degreed cams, and some other minor mods. Even on a strait with my buddie's 04 CRB600RR, which is decked out, I was wasting him until about 115. He is about 135lbs, and also a trackie. The bike is capable, just needs to be pushed with more confidence. AND FIX THE HORRIBLE BRAKES!!! Calipers and Master are very much welcomed, and will reward you greatly.
Old 12-03-2005 | 06:06 PM
AZZKIKER's Avatar
Putting a jet kit and a bmc race filter with full 2bro exhast system helped a ton on my bike. The whole setup kinda uncorked the motor.
Old 12-07-2005 | 12:13 PM
Rollingalong's Avatar
Rollingalong
Don't forget the 04 up R1 . Even on the street it will kill a SH in a 6th gear roll on from 60mph . Hard to compare 108 hp to 168 hp in a lighter chassis .
Old 12-07-2005 | 04:23 PM
bluesman's Avatar
bluesman
Well, who cares about cranckshaft figures!
No, just joking. Thou GSXR1000 K5 eats every other liter sport for breakfast so far , simple reason - genuine 168 kg with genuine rear-wheel power of 169 bhp (as per dyno)... R1 does not even come close on midrange, that's why I mentioned GSXR - kinda trying to sweeten a pill of Shawk being sluggish buddy
But - roll-on from 60 mhp it's bad pick. 60 to 80 even ZX10 slower than Shawk, believe it or no - thou Shawk well behind in all other spots up to 60 and after 80
I can't understand why exactly 60 to 80 (tried - true, superfast there), but even sportrider.com figures confirming it - they got figure of 2.78 (!!!!!) sec. roll-on 60 to 80. T ogive you idea - R1 '04 is at 2.8, '02 r1 a bit better - 2.79, and only only other bike to be faster is GSXR '04 with 2.64 according to them.
It is not actually so much down to power, it is down to slower rpm pick up.
That most annoying thing for me about Shawk - slow rpm pickup....
I have my payback on sunny days when R1 riders have to stop to prevent their...well....their...you know... :wink: from grilling - those underseat pipes are not best thing in R1. And - on long trips, after which they have to visit orthophedist
Old 12-07-2005 | 06:38 PM
All that said on track days on a fairly tight track I can still beat those liter I 4 bikes! It all depends on the rider of course but with a rider with similar skills I get passed in the straights and blow by them in the corners. I'm able to get on the gas a lot sooner then the more powerful less linear bikes because they'll lowside. After a sprocket change my buddies gsxr no longer pulls away from me we just swap posistions back and forth. Now that's FUN!!!!
Old 12-08-2005 | 04:42 AM
Rollingalong
I was quoting RWHP
The 04 R1 went 2.75 and trapped 145.3 through the 1/4 .
ZX-12R - 3.17 and trapped 143.7
Hayabusa 2.70 - 143.9
The new R1's are no slouch and not aknowledged as even being a motorcycle by " some " of the geeks that are spellbound by the GSXR . Yamaha does not support an AMA bike but in the WSB , Yamahas do well and will be better in 2006 .
And you forgot something ... the Superhawk does the 60-80 thing in drum roll ..... 5.00 seconds . To add insult to the injury the 2004 Honda 599 went 4.87 .
Something not taken into account is the tall 6th gear on the SH but never mind . Stick it and a 1995 ZX600 in 5th and the Kawasaki walks away still yet .
They are good bikes , fun to ride but they are what they are .... and discontinued to boot .
Maybe Honda will build a V4 sport-bike soon .
Old 12-08-2005 | 07:27 AM
Regarding the on-going debate about roll-on acceleration, I can quote three figures for the VTR from memory for the infamous 60-80 times:
Sport Rider magazine: 2.78
Cycle World: 3.5 (may have been a 50-70 time, however, would have to check)
Motorcyclist: 5.00
As you can see, there is quite a difference in the stated time for what is supposedly the same bike. So, can anyone with real-world experience shed light on this mystery, especially in terms of how it compares to other bikes?
Finally, I seriously doubt that a 599 would dust the VTR.
Old 12-08-2005 | 08:13 AM
bluesman's Avatar
bluesman
I was quoting RWHP
Now we talking topic I really know!
OK, first of all - I had Hornet 6000 what you call 599 for 4 years. Did loads of miles on it, even before they were on sale in US. And - 2000 version, which is slightly madder than 2004 Hornet.
And - roll on? FORGET about 599 doing it faster. I LOVE Hornet 600 (called 599 in US), but it NEVER can do Shawk on roll on. It can beat it even on 0-60, but not on rollon. I am speaking from own experience and later from riding on Storm with whole Hornet Club of Belgium.
Shawk does 60-80 waty faster than 5 sec. When it will turn warm here (april perhaps) I will borrow accelerometer from one guy here (he times his racing cars with it) and will try. But it isn't 5 sec.
Out of listed mags - sorry, it is just me - but check rest of bikes figures in this mag. See some incnsistency? Yep. It is all top gear roll-ons for different spot on mph, at different heights and conditions. Useless data. I am dissapointed with MO there - no respectable mag ever post numbers with such innacuracy. PB or MO never ever post a figure without explanation.
About BHP figures - I guess we talking highly tuned bikes, or?
RWHP - 04 R1 nowhere near 168 BHP on dyno in stock, even GSXR isn't . Of course it is my opinion, nobody else entitled to agree except all European bike mags saying same. If I will find those dyno scans I had chat on with my Russian friends, who had "dyno day" with bunch of 1000cc sports, Tuono and RC51 SP2 - they even fitted stock cans back to make it fair.
Basically - one mag I do trust with numbers is Performance Bikes - UK one.
Here we go: 04 R1 BWHP: 148,95 at 12700, 69,74 lb-ft at 10200 rpm and 05 practically same.
'05 GSXR is 153,39 at 11300 rpm, 77,79 lb-ft at 8500 rpm.
Which again - proves nothing about "who's faster", just me being pedantic booooring man!
I like all bikes, make does not matter, but in US seems that R1 (and R6) is a big hype since it was released - IMHO yes, back than it was miracle, but it faded long ago. It is kinda back this year big time, but since I don't care about this category bikes....
But - I have no clue why I wasting your time guys typing all this (winter bore?) I mean - I have no point to prove Shawk IS sluggish comparing to those bikes, but if I'd wanted to beat hell out of R1s I'd be racing on GSXR or NSR500 but I do not give a damn - I am sport-touring at small twisty roads mainly...
Old 12-08-2005 | 08:17 AM
superbling's Avatar
I've done it very unscientifically by counting (one thousand one, one thousand two....) and it's closer to five than it is to 2.78 and I have a 15t!
But as Superhawk22 says, it's being able to USE the power SAFELY and CONSISTENTLY that makes all the difference. Only top shelf riders on top shelf rubber (slicks) can utilize that kind of power.
On another note about bike roll ons in general, I see this over and over again; complaining of having to drop down a gear to pass or to get "into the meat of the powerband". So what's wrong with that? Geez, do you want an automatic? Oh the horror, I had to shift down a gear!
