Headlight upgrade to 85/80W plus relay kit (comparison pics)
Old 08-20-2009 | 01:06 AM
CentralCoaster's Avatar
Ok, I've been promising these for awhile. Finally got my new 85/80W Osram H4 bulb in the mail. Says "off road use only" on the box.
Here's some pics: 2nd shows high and low beam, it's bright as hell but the lowbeam keeps the beam down. 3rd pic you can see my shadow on the tree a block down.
I set the camera on manual mode so it wouldn't try to adjust different for each photo.
Old 08-20-2009 | 02:25 AM
nerostorm's Avatar
Sydney, Australia
nerostorm is on a distinguished road
cool thats awesome stock globes are rubbish
Old 08-20-2009 | 08:43 AM
LineArrayNut's Avatar
I could ride in
nice work, thanks
Old 08-20-2009 | 01:55 PM
Would be interesting to compare with a HID setup. I'll give that a shot if I happen to be down at bikenight or something with other bikes.
Old 08-20-2009 | 02:20 PM
revhead1957's Avatar
revhead1957 is on a distinguished road
Moral of the story, at the very least replace the stock wiring setup with a relay set!
Old 08-20-2009 | 02:48 PM
cliby's Avatar
nice job and thanks for taking the time to get comparison pics - a lot of work to do that right. I am an electrical infant. can you explain the relay deal - what it does, and how you set one up for this? any downsides?
thanks
bill
Old 08-20-2009 | 03:17 PM
Stevebis1's Avatar
thanks
bill
Search on "Eastern Beaver"
Old 08-20-2009 | 04:28 PM
cliby's Avatar
thanks much Steve. and for posterity, here are some links to threads on this eastern beaver relay and general info on voltage drop/light intensity drop below.
So in general is this typical of all bikes? age related? manufacturer related?
https://www.superhawkforum.com/forum...eastern+beaver
Old 08-20-2009 | 05:25 PM
uchi's Avatar
does this relay kit basically just give you full power from the battery? is it a basic relay setup or is there more to it? and whats the installation like on this? its something id like to look into. my buddy was behind me doing a night run on his cbr 600 and his hi beams outshined mine. from about 3 lengths back.
Old 08-20-2009 | 06:19 PM
Actually the 80W upgrade helped slightly more than the relay kit, and is easier to install and cheaper. But both of them are nice to have.
Old 08-20-2009 | 06:21 PM
Yes, it puts full battery voltage to the light... like 14V vs. 11V. The kit is basically plug & play. I zip tied the relays to the frame inside the left front fairing area. The details are in those links.
Old 08-20-2009 | 08:59 PM
uchi's Avatar
right on thanks alot
Old 08-21-2009 | 07:40 AM
Unfortunately these problems are definitely manufactured faults... If you do the math, which obviously Honda didn't do it's obvious you will get voltage drop with wiring that thin for that length... Then add in a direct inline switch in the handlebar adding resistance to the circuit and it borders on stupid...
I had a friend here in Sweden with an almost new 07 bike (less than 300 km, and this was when it was new in years as well...) complaining about the bad light... We measured and he had ~10V to the bulb...
A relay kit later and the bulb gets full voltage...
avramd
12-15-2009 09:37 PM
CentralCoaster
11-12-2008 04:05 PM
CentralCoaster
10-06-2008 02:02 PM
BirdofParadise
03-15-2006 12:39 PM
