Header Wrap
Old 03-29-2008 | 07:50 PM
Pimpsterbim1's Avatar
JAMES
Header Wrap
Anyone use that exaust wrap on their headers.... i was wondering if it even makes a difference... thanks..
Old 03-30-2008 | 04:05 PM
I've had mine wrapped for two years now and just re-did them last week as I had the exhaust off to do my 2-1 conversion. After two years of operation the pipe was still in fine shape.
The main reason for doing mine was to keep the pipe cooler as it runs right under the sump and radiates heat to the engine. An additional benefit is that a warm pipe has better scavenging so it can only help performance.
Old 04-12-2008 | 08:41 PM
ride57's Avatar
ride57 is on a distinguished road
I have had it on my sportster for about 6 years. Different pipes, but I always wrapped them. No problems.
Old 04-13-2008 | 07:41 AM
FTMS's Avatar
The only problem I have seen when you wrap headers is if you have a carbon fiber can it can dis color the can because of the extra heat that the exhaust now carries.
Old 04-13-2008 | 08:18 AM
HawkRider98's Avatar
I wrapped mine mainly to protect my lower from getting toasted and it has worked for that. I run TBR high mounts/header and have not disabled the PAIR yet and get no popping on deceleration. Sound is improved with a deeper but not as loud growl.
Old 04-13-2008 | 08:24 AM
BlackHawk996's Avatar
i support twins
mine need to be re-wrapped, had a lower on mine and the exhaust rubbed against at the bend of the bend of the front header causing my wrap to basically powder up right there and then it burned a hole in my fairing. so im going to re-wrap and cut a hole in the fairing at that bend to nothing crazy happens haha.
Old 07-15-2008 | 03:25 PM
BLAKCK HAWK's Avatar
BLAKCK HAWK
WHATS UP , HELP ME, what's this header wrap stuff u talk about ?
Old 07-15-2008 | 03:33 PM
zmaniv's Avatar
The internet is your friend.
http://store.summitracing.com/egnsea...alse&N=700+115
NZSpokes
04-23-2014 06:40 PM
Tebs
04-25-2013 06:45 PM
Bluesuperhawk83
05-27-2011 12:20 AM
Dnagmour
04-21-2010 03:13 PM
SLSblackhawk
07-29-2008 06:26 PM
