Devil High Mount Questions
Old 11-19-2010 | 06:15 PM
aaugsbu's Avatar
aaugsbu is on a distinguished road
New to this site and had a few questions I thought I would through out there and see if I could pic the brains of other owners who have Devil High Mounts. First, I have seen other pictures of Superhawks that have the baffle taken out of the Devil exhaust. Mine do not have a screw that you can take out to remove them. I was wondering if you can take them out a different way? Also, what kind of jetting do you have? Lastly, it looks like there is a stain on part of the high mount pipe where someones shoe got to close and the rubber came off. How do you remove this from the pipe? I have included a pic of the baffles. Yes, I know the tail light turn signals are horrible, they are being replaced by a intergrated very soon.
Old 11-19-2010 | 07:31 PM
drew_c14's Avatar
I could be wrong, but I don't think you have any baffles in those pipes.
Old 11-24-2010 | 04:42 PM
aaugsbu's Avatar
The opening at the end of the exhaust is not as wide as the stainless steel part. I'll try to take a better pic tonight.
Old 11-24-2010 | 05:04 PM
Yeah, but that's a design issue... They stuck a stainless oval tube on they for bling-bling... The smaller round tube is the same diameter as what passes through the core... I wouldn't mess with that...
Old 11-24-2010 | 07:33 PM
JPP's Avatar
JPP
I bought Yamadog's Devil Carbon high mounts. They came with the silencer removed but were included with the sale. They were removed by grinding or drilling the single rivet out. I will be reinstalling them with new rivets. The outer opening is quite large.
Old 12-11-2010 | 10:42 AM
aaugsbu's Avatar
Here are the pictures of the end opening to the Devil highmounts. They are aluminum cans with rivets in the ends. As you can see in the pics there is a baffle inside that some have chosen to take out.
Attached Thumbnails Devil High Mount Questions-100_1819.jpg   Devil High Mount Questions-100_1817.jpg
Old 12-11-2010 | 10:04 PM
t-dogg's Avatar
I would drill the rivits and pull it out. You can always put it back in with new rivits and just re-use the packing
Old 08-24-2011 | 04:57 PM
MikeMcW's Avatar
MikeMcW is on a distinguished road
I have been looking for an answer to this as I think the baffle looks dumb. So I would just screw out the rivets at the end cap and then remove the baffle and rerivet the end cap back on?
Would this cause any jetting issues?
Old 08-24-2011 | 06:00 PM
Originally Posted by aaugsbu
Lastly, it looks like there is a stain on part of the high mount pipe where someones shoe got to close and the rubber came off. How do you remove this from the pipe? D
Well there are several ways but probably the easiest way to get hardened melted shoe rubber off the pipe is when the pipe is good and hot wad up a towel (so you don't burn yourself) and rub it with some polish. It'll be soft and come off much easier when it's hot. If necessary you can always wet sand the metal and then polish it.
Old 08-27-2011 | 03:42 PM
Dan Cronin's Avatar
Any chance the end cap from another make is the same size as your silencers? You could try opening that end cap to your hearts content and not worry about trashing the original.
Another reason I ask is because I run a single Devil can on my SV650 and it doesn't have a baffle. When cranked up the thing is embarrassingly loud and it a much smaller engine. I can only imagine what no baffles on the SH would be with those Devils. Either way, have fun.
little squirt
08-16-2009 03:47 PM
FRANKSVTR
04-08-2009 08:51 PM
blackhawkrising34
03-08-2009 07:00 PM
epleeds
08-18-2008 03:37 PM
david.k1200
06-23-2008 02:12 PM
