Connecting rods measurements
Old 04-16-2009 | 05:26 AM
gboezio's Avatar
Not tearing in the engine yet, but has anyone here measured the Big end ID, small end ID, thickness and distance between both ends ??
I'm looking for stronger rods.
Thanks
GB
Old 04-16-2009 | 05:54 AM
shayne's Avatar
Can't help you I am sorry.
But why do you want stronger rods? To my knowledge, this is not a weak point in the engine. I believe you will break the crank (engines 140hp and up from memory) before having problems with the rods.
Old 04-16-2009 | 06:41 AM
FL02SupaHawk996's Avatar
Fastest Color
Thanks
GB
I'd beat Roger would tell you!
http://www.revolutionuk.co.uk/
Old 04-16-2009 | 06:49 AM
gboezio's Avatar
Going to higher RPM, the crank will destroy itself, forced induction setups tend to bend the rods, on boosted bimmers 75-80 hp per rods is the upper stock rods limit.
I'm trying to find some cheap replacements first.
Mostly for next winter project.
mikstr
12-19-2010 06:36 AM
mikstr
06-11-2009 09:03 AM
mikstr
02-27-2009 11:54 AM
Miked9
02-17-2009 02:17 PM
gboezio
04-10-2007 07:36 AM
