Chain length
Chain length
I have done a search on this and I saw one person post an answer, but I just want to check and see if there is a consensus on this. I currently have a 16/43 set-up with a stock chain. I purchased a 44 tooth rear sprocket last year and was waiting til this year to install it. I am about to purchase a new chain thru a place that will cut it to length for no extra cost. So my question is, should the length be 104 links, plus the master link? Thanks in advance...
I think that's kind of like asking, what's the best oil, or what are the best tires.
I replaced my OEM chain at over 41k miles with a DID 530 ZVM2. It was 120 links, so I had to cut it down, no problem, since I got a good price on it at the dealer.
The reason I replaced it with DID was mainly based on DID's reputation, and I wanted the best quality.
You want the chain to be O or X ring, to keep grime out of it, and you want it to be a decent quality, so that the rated tensile is roughly close to the real... Other than that, pick whatever you like, the difference is mainly name/looks... And in the end the old one, "you get what you pay for", is still a rough estimate... Cheapo chains usually wear a lot faster...
I prefer DID myself, but like said above, it's like an oil thread...
duran
08-27-2007 08:57 AM
