Carillo rods: opinions please
Old 06-04-2009 | 07:09 AM
Now that it finally seems as though my Akra full system will make its way home, my attention is turning to other things.
My plans at this time are to install the exhaust and new velocity stacks together, get it dyno tuned (should yield an honest 115 or so hp) and enjoy the bike in this state until the end of the summer.
I have most of the parts I need for the rebuild now (OS JE pistons, rings, will basically just need bearings and gaskets but need to wait to get the proper engine codes before ordering anyhow). I will also be installing Truck`s CCTs (if he ever returns my messages...) as well as Hyperplate aluminum clutch plates, new OEM fibre plates, and a Factory Pro detent arm kit.
All this leads to my question: should I perhaps put off the rebuild for a bit (as I do not have unlimited funds... my 11 month-old daughter helping in that regard, lol) and get Carillo rods (mostly for weight loss and quicker response) and a re-balancing of the crank (would love to have it smooooooooooooooth) or should I just go ahead and get it rebuilt in the Fall and be done with it? Part of me is thinking to wait a bit and do it up the best I can (meaning new rod and balancing) while the other part wonders if the added expense would be worth it?
Comments?
Old 06-04-2009 | 07:18 AM
Little_Horse's Avatar
2nd mouse gets the cheese
if you are going to do all that work you may as well "do it right" and do everything you want to do at the same time.
Old 06-04-2009 | 07:57 AM
MC Leather's Avatar
MC Leather is on a distinguished road
For a street and "fun" motor I would say save you money stick with the stock rods and spend the cash on the 11 month old.
Old 06-04-2009 | 08:06 AM
two good points, thanks gents
Old 06-04-2009 | 09:39 AM
hawxter996's Avatar
ole dirty bastard
unlees your going to do a bunch of drag racing,save your money.
from what i hear stock bottom end is plenty strong.
Old 06-04-2009 | 09:42 AM
Carillo rods would be more for the weight savings than anything else (loss of reciprocating weight would allow engine to spin up faster).
Looking at the additional costs it would entail (cost of rods, shipping, engine balancing), it is probably not worth it I am beginning to think....
Old 06-04-2009 | 06:15 PM
gboezio's Avatar
Hey Mik, do you have the full measurements of the VTR rods, I would like to find some replacements, there's plenty of premium quality rods littering the junkyards, I have eight 143 mm rods in my garage, BMW use high quality forged sintered caps rods, you can get them in many sizes, If the VTR journals are the same size or bigger, it can be machined down to spec, that's the next project tough
Carillo are probably the best rods you can get, but Eagle is the best bang for the buck.
I have a little girl, 7 months old and I'm getting all the family needs before I put a penny on the bike, luckily I have some extra cash from working like crazy so I can still feed my projects, it takes longer but it's the only responsible way to go.
Old 06-04-2009 | 07:20 PM
The rods are still in the engine, which is still in the bike. Nothing is apart at the moment so I can't help you with any info, sorry. Like you, I am not cutting corners on the family but my bike is my treat, my reward for working long hours.
Old 06-04-2009 | 07:48 PM
HRCA#1's Avatar
I hate to point out the obvious but get a lightened flywheel will give you way more bang for the buck than rod's or crank lightening at a fraction of the cost. The only reason to replace rods are A the stock rods can't handle the loads or B you've got more money than brains or C you're really into the last gram of reciprocating weight removal to some particular purpose.
I saw lightened flywheels here for $140 weighing nearly 50% less than stock..how much are Carillos and would they be half of stock..I doubt it and the cost would be far far more.
Really some of you guy's don't show a lot of common sense when it comes to performance vs expense especially when you're talking street bikes. For my money the chassis improvements and mild engine (stage 1)tweaks give you as much as you can reasonably expect from the SH design.
And if it's a choice between your families needs and your SH well there really isn't a decision is there.
Old 06-04-2009 | 08:04 PM
Well, sir, it just so happens I already have a lightened flywheel. As well, I have magnesium rims and a machined rear rotor. Need more? Have a look at my signature! Good enough for you?
AS far as family vs. hobby choices, my family lacks nothing. Also, I don"t drink of smoke like many others do so my bike gets most of my hobby money.
Perhaps you should read a bit before making statements of the kind!
Old 06-04-2009 | 08:08 PM
gboezio's Avatar
I think that his bike has pretty much all that's possible to improve.
A lighter flywheel and lighter rods are quite different, light flywheel just change engine inertia, using less power to accelerate the engine, while rods actually can make horsepower, by raising the RPM limit according that the cams, ports, compression are going the same way.
Old 06-04-2009 | 08:14 PM
FWIW I am not looking to raise my rpm limit as it's a street build and not a race build (hence my reason not to seek out oversize valves, along with re-timing my exh cams by two degrees to move the power down the rev range). I also plan on keeping the bike for many years to come and to ride many miles along the way (so I want reliability adn durability).
I am trying to build my take on on the ultimate VTR street bike, with light weight, awseome brakes, excellent handling, good suspension and monster mid-range. I am quite close to my goal and the last few mods should move me firmly into Shangri-La.
Old 06-05-2009 | 06:29 AM
HRCA#1's Avatar
Dude..you said you wanted opinions, I gave you mine, but at the end of the day it's your money do what you like.
Old 06-05-2009 | 07:35 AM
RCVTR's Avatar
Rods and lightened crank will make a significant change in the seat of the pants acceleration. There is no other shaft on the bike that sees the RPM range, or rate of change in RPM as the crank.
It won't significantlhy change dyno results, but will change acceleration and engine braking significantly. The crank is heavy on a twin.
I think you've already made up your mind. But I say go for it. Is it sensible? Of course not.
Old 06-07-2009 | 05:52 AM
shayne's Avatar
Nothing wrong with the stock rods for your purposes, so weight would be the only reason to swap them I think.
My brain tells me that the entire reciprocating assembly will work together in terms of acceleration. I think that if you wanted to save a few grams (perhaps ounces for you?) then it would be easier to just lighten the flywheel a bit more. Much simpler and cheaper for the same result I think.
Having said that, your assembly will be close to mine in terms of its weight, given our similar light weight components. Your magnesium wheels excepted - they will be lighter than my ally ones. I suspect you will be happy with the result when it is assembled without needing the expense of Carillo's.
I reckon you would be far better off saving the coin to put towards some flat slide carbs. Better bang for your buck there I reckon.
Old 06-07-2009 | 09:51 AM
cameron's Avatar
man you still have the best looking vtr i have ever seen.
Old 06-08-2009 | 10:12 PM
shayne's Avatar
Thanks Cameron.
Old 06-08-2009 | 10:47 PM
RCVTR's Avatar
Stock rods are fine form a strength standpoint.
Carillos are just a lot lighter and you take a corresponding weight off the crank as well.
But it's true, it is a bit pricy (~$650) and you should be able to get close to the same result taking more off the flywheel. But the smaller the flywheel gets, the smaller the change in inertia becomes.
Old 06-09-2009 | 05:54 AM
Not having unlimited funds (I was quoted $600 US for the Carillos; add in shipping plus the US-CAN $ exchange rate and it gets expensive pretty quickly), I think I will opt for stock rods and get the crank balanced. Besides, I will be running aluminum clutch plates in addition to all my other lightweight goodies (machined rear rotor, 520 chain and aluminum rear sprocket, magnesium wheels, lightened flywheel) so it should be ok (runs great now, can`t wait to see how it`ll go with the pistons, Akra and velocity stacks!!!)
Old 06-09-2009 | 05:23 PM
shayne's Avatar
All it needs now is a flux capacitor.
Old 06-09-2009 | 05:40 PM
On order, he he The big one too!!!!!!
Old 06-09-2009 | 11:33 PM
RCVTR's Avatar
My RC51 is faster...
Old 06-09-2009 | 11:44 PM
killer5280's Avatar
Does it run?
Old 06-10-2009 | 03:43 AM
Does it run?
Ouch... That was below the belt I think...
Old 06-10-2009 | 05:47 AM
indeed it is (and I would LOVE one just like it). However, my VTR is street-legal, more comfortable and practical and for me, those matter more Besides, if all I cared about was speed, I would buy an I4 (take your pick: ZX-14, Busa, R1, BMW 1300,...) and be done with it. Rest assured, however, that once my bike is all put together, there will be few bikes able to stay with it in a roll-on between 60-100 mph or out of tight corners... he he
Old 06-10-2009 | 07:09 AM
RCVTR's Avatar
Does it run?
Welll....
No...
Not right now...
But when it does, it's pretty amazing. Better than expected.
I'm building a Subaru engine with my son, so the bike has slowed down a bit.
The thing I dread the most is all of the paint prep.
Old 06-10-2009 | 07:12 AM
RCVTR's Avatar
I wish I could have another VTR street bike. I know exactly where you're coming from.
There are lots of faster bikes than the RC. but it's the perfect track bike for me.
Old 06-10-2009 | 07:15 AM
You have a very, very nice bike!!!!! I am certain it must be a real blast to ride around the track
Old 06-11-2009 | 08:56 AM
RCVTR's Avatar
I was just starting to realize how great it is.
I've been doing a lot of thinking about mental preparedness. I was in such a rush to get the thing running and hurried every minute until I was on the track, riding a motorcycle for the first time in 3 years.
I used to be rpogrammed to be ready to pull in the clutch if the engine suddenly went BANG. But I had not taken the time to mentally prepare, and suddenly found myself going really fast on a very enthusiastic machine. When it was suddenly pulling me toward the edge of the track, I reacted the wrong way.
Note to self: Be prepared, next time and every time!
Old 06-11-2009 | 09:03 AM
Yep, program your sub-conscious so that everything becomes instinctual.
mikstr
12-19-2010 06:36 AM
mikstr
09-13-2010 05:55 PM
gboezio
04-16-2009 06:49 AM
mikstr
02-27-2009 11:54 AM
gboezio
04-10-2007 07:36 AM
