Carb to Fuel Injected
Old 04-26-2007 | 09:48 AM
SH1000MA's Avatar
SH1000MA is on a distinguished road
Has anyone converted there V-Twin to fuel injected?
If so, was it easy to do?
How much does it cost?
Is it really benifical?
Does it affect the sound of the bike?
I probally have more questions later!!
Old 04-26-2007 | 11:20 AM
SH1000MA's Avatar
so i take it this is not something that is usally done
Old 04-26-2007 | 11:40 AM
Probably easier to buy an RC51 and put helibars on it. No, I've seen nobody do it in the 7 years that I've been on forums and email lists.
Old 04-26-2007 | 11:42 AM
That guy doing a turbo listed a megasquirt FI in his parts list.
Old 04-26-2007 | 12:20 PM
SH1000MA's Avatar
How bout a big bore kit? where can you find those?
Old 04-26-2007 | 01:01 PM
hawxter996's Avatar
ole dirty bastard
all of your questions can be answered by the search button.
besides we dont answer questions around here,
we just call names!...........lol!
Old 04-26-2007 | 01:04 PM
Now now, we want him to feel welcome..
Old 04-26-2007 | 01:11 PM
hawxter996's Avatar
ole dirty bastard
please notice....lol!
Old 04-26-2007 | 02:03 PM
Zedicus's Avatar
Zedicus is on a distinguished road
if by welcome you guys meen hashing the n00b. then yes you always make newcombers feal welcome.
Old 04-27-2007 | 05:57 AM
SH1000MA's Avatar
i created this thread to have a dissucion, i know i can search but its not as fun.
Old 04-27-2007 | 09:24 AM
penst8grad's Avatar
penst8grad
I looked at the megasquirt setup before, but just seems like more time than I want to bother with.
Old 04-27-2007 | 10:06 AM
I wonder how hard it would be, and if it would be worth transplanting EFI from a TL1000 or SV1000? My guess is that it would be a lot of work, and not much gain.
Old 04-27-2007 | 06:49 PM
SH1000MA's Avatar
well going fuel infected would be more responsive.
Old 04-27-2007 | 07:27 PM
How do you figure that? For strictly engine response, a well set up set of carbs works quite well (just not as clean or economical due to the unburned gas making its way into the exhaust). This topic has been discussed at length before, the easiest way to do it would be to fit the EFI sytem from a European Varadero bike. In the end, however, it would likely be easier to simply purchase an entire Varadero engine (slightly different state of tune, less hp, more torque and at a lower rpm) if what you want is the equivalent of a fuel injected VTR.
Old 04-27-2007 | 09:47 PM
I Luv carbs
I don't want a FI bike. I like being able to adjust manually (though it is more of a PITA). The VTR has the largest carbs Honda ever put on a 2wheeler, and carbs are more dependable and as sophisticated (compared to the Amals, Delortos and Bings when I first stated riding). The main reason they went to carbs was for better emissions, noise and economy, not originally for performance. Long live carbs!
Old 04-28-2007 | 09:00 AM
gboezio's Avatar
I have been trough the brainstorm to convert my bike to fuel injection, but since it's for a turbo setup it will be slightly different from a NA fuel injection system, the way I would do it for NA, I'll tap and plug all holes on the carbs and use them as throttle bodies, retaining the TPS, drilling the carb body to place an injector. I'll use the upcoming Microsquirt since it's the only ECU to have a dual ignition output that can control odd fire engines. Microsquirt uses speed density algorithm but I think you can use a MAF sensor as a primary air metering device as well, witch I prefer for NA applications.
The difference for forced induction are, single throttle body, custom aluminium intake with a plenum, MAP(Manifold Absolute Pressure) based algorithm instead of Mass Air Flow.
Fox
12-14-2010 12:46 PM
Auron
07-31-2010 07:46 PM
seb421
02-04-2009 06:49 AM
VFR79
04-30-2008 08:12 PM
HawkRider98
04-01-2008 10:17 AM
