Anyone ever put a toggle on the radiator fan?
I thought it might be a good idea if it's not too much trouble. I'm concerned about how the fan doesn't kick on til she's roastin', and then stays on for a long time. Sometimes even after I've got her back in the breeze. With a toggle, if I know I'll be stuck for a while I could kick in the fan before she got so hot, and cut it off the moment I got out of first.
Just 1 wire on my '02. I have the rocker switch (plastic) glued to the underside of the brake master cylinder - also plastic so it doesn't show much. All the sensor does is create a ground through the radiator case when it hits the preset temperature.
I ride parade speed in the hot city daily & wouldnt live w/o a switch. The stock one comes on way too late.You can splice right into the sending unit on the right rad & mount the switch in the right fairing. This doesnt impede the normal functioning. I flip it on when the temp is a bit more than 1/2 way.
