aftermarket turn signals / tail light
Who has aftermarket signals, preferable low profile? Because of the weird method of mounting them to the inside fairing, I'm having trouble finding a good pair of signals to replace my stock wind sails.
What have you guys found that looks good?
Got a cheap two wire set of LED front turn signals, then used a Hotbodies integrator to add a running light to them. They fit in the stock turn signal hole just right. I'm also using an LED rear taillight with tail/stop/turn all built in.
Watsen design MicroAlloy Style (with running lights)
http://www.watsendesign.com/Honda_Pr.../Honda_new.htm
More of an undertail than "eliminator" kit - I recomment the mototech. I believe they or the clones are still available on ebay in the $125 range or so. They include flush turn signals but they are hard to see so I would suggest also adding the LED integrated turn signal light also.
Magnus
05-29-2014 07:52 PM
johnclopp85
05-13-2009 08:20 AM
skokievtr
05-01-2007 11:11 PM
seaton001
03-19-2007 06:46 AM
