954RR swap or Racetech
Old 06-22-2005 | 07:12 AM
RVO27's Avatar
RVO27
Hey everybody,
I am contemplating a front-end swap for my 98'. But I'm not sure if it's worth it performance wise. Right now I have my stock front end upgraded with Racetech .95 springs (I'm about 250lbs) and cartridges. My friend has a complete 954 front end that he is going to sell. What I'm not sure of is how my Racetech forks compare to the stock 954rr front end. I really do like the USD forks on the 954rr front end and would probably decide to do the swap if the 954rr forks are even close to the Racetech's. Any advice would be greatly appreciated. Thanks!
Old 06-22-2005 | 10:22 AM
RVO27's Avatar
RVO27
Re: 954RR swap or Racetech
Thanks for the reply rc996. Have you done the 954rr swap? I just checked Racetech's site and they list the 954rr stock spring rate as .710 kg/mm. I guess they're a little softer than the springs I have now. I think I'm still going to do it. I can eventually replace the springs with some Racetech's when I need to have them rebuilt. And .710 is better than the .585 stock shawk springs.
Old 06-22-2005 | 11:22 AM
RVO27's Avatar
RVO27
Will the RC51 springs fit the 954 forks?
Old 07-01-2005 | 11:13 AM
RVO27's Avatar
RVO27
I'm going for the 954 front end. Does anyone know if the 954 clip-on's work. I don't mind if they interfer a little when turned fully to one side. I was looking at the 954 top triple and it has a downward step in it by the forks.
[img=left:dab2024fb1]http://i20.ebayimg.com/04/i/04/63/b4/11_1_b.JPG[/img:dab2024fb1]
I'm not sure if the stock 954 clip-on's will work or if I need to look into some aftermarkets. If so I was looking into these clip-on's on ebay.
FL02SupaHawk996
11-11-2008 06:03 AM
superhawk205
06-19-2008 08:00 AM
superhawk205
06-08-2008 09:07 AM
Speed_Demon
04-24-2008 04:36 AM
Speed_Demon
12-26-2006 05:24 PM
