15t/54t sprocket any info ? single exhaust ?
Old 05-20-2005 | 10:22 PM
mrjakeanderson's Avatar
mrjakeanderson
I already bought, just waiting on them to come in. A RK 520 chain and Vortex 15t front and a 54t rear sprocket. I should be doing 2nd or 3rd wheelies in a few weeks. Ill tell you all about it. is 54t able to fit on the back?
Also my left exhaust is frickt up. Can I just block the Y pipe so that just my right exhaust takes all the pressure and take off my left pipe ?
Old 05-21-2005 | 04:51 AM
yellowvtwin's Avatar
yellowvtwin
Re: 15t/54t sprocket any info ? single exhaust ?
yep the sprocket will fit on with little fuss VTRstunter on www.ozfirestorm.com has the same from memory..
you can block off i pipe st the 'y' section but it would be down on power and probably pop back thruogh the carbs a heap much back pressure
Old 05-21-2005 | 10:13 AM
BooYeah's Avatar
BooYeah
just buy another factory off ebay, they go for around 50 or less.
LineArrayNut
10-05-2009 04:25 AM
epleeds
07-06-2008 09:34 AM
bigmike1219
01-31-2008 02:56 PM
reaper
10-19-2007 07:45 AM
trickphoto
07-19-2005 06:55 PM
