Removing "Superhawk 996" Decals
Old 06-15-2005 | 12:39 AM
does anybody have any tips on removing the "superhawk 996" decal from the fairing without using a razor blade?
Old 06-15-2005 | 04:35 AM
caffeineracer's Avatar
caffeineracer
Re: Removing "Superhawk 996" Decals
you can heat it with a blow dryer and peal it off while keeping the heat on it.
then remove any residue with alcohol,
also you can smooth the top (non cutting edge) of one of those cutters you break the sections of blade off of, and carefully cut around what you want left on (like the 996) and leave just that part on.
to do that you carefully slide the smooth part of the blade over the plastic with the cutting edge aiming forward, this cuts the decal without cutting the plastic
~Jeffers
Old 06-15-2005 | 06:22 AM
cdyer77's Avatar
cdyer77
I dont know if a blow dryer gets hot enough but try it. If not then you need a heat gun. Run it over the decal while peeling off the sticker. You can use honda polish to remove the sticker residue. Just spray it on and let it sit a few minutes then rub off.
Old 06-15-2005 | 08:37 PM
thanks guys, i got it. the blow dryer did the trick of getting the sticker off. and about an hour or rubbing alcohol and a whole roll of paper towels finished off the residue.
hondahawk
12-10-2014 02:27 PM
19superchicken98
01-30-2013 02:35 PM
Little_Horse
09-09-2009 08:14 PM
Mr Toad
07-22-2007 07:25 PM
saxman
06-21-2007 06:11 PM
