rear set install questions
Old 01-30-2014 | 05:44 PM
jscobey's Avatar
installing the danmoto rearsets but i guess i need to remove the whole swing arm pivot bolt to put on the right side rear set. do i need to have the bike hanging when i remove this bolt? it seems like once i take it out the bike will collapse if i dont have it hanging from the ceiling
Old 01-30-2014 | 06:20 PM
taskmasta's Avatar
Pew Pew...lasers
what i did was buy another pivot bolt and used it to push out the old one, so when the old one is pushed out the other bolt takes it place.
Old 01-30-2014 | 07:32 PM
jscobey's Avatar
ok handled the pivot bolt. now how the hell do you get out the little pin thing that goes through the bottom of the threads on the rear master cylinder?
Old 01-30-2014 | 07:52 PM
jscobey's Avatar
i seriously cannot get this stupid pin out. it loos like two halves that have teeth that interlock. im so annoyed!!!!
Old 01-31-2014 | 02:53 AM
Mine had a split pin in it!!!
Have a look at the back of it.
You may need to unbolt the M/C from the original rear set.
Hope this helps you.
Old 01-31-2014 | 08:26 AM
jscobey's Avatar
got everything installed and it looks and feels great. the only issue is that it seems tht one side is higher than the other. i didnt even notice it even after i sat on it a few times to get a feel for them until i whipped out my tape measure and started measuring distances. i was wondering if anyone else has this issue. i know i read on here that someone else had the problem but im wondering if its because of an incorrect install or thats just how they mounted up
Old 01-31-2014 | 08:59 PM
Mine are the same height .
Check your install, maybe different holes on backing plate?
Old 01-31-2014 | 09:35 PM
jscobey's Avatar
someone on here said it had to do with the locator bolt holes below the swing arm pivot bolt being a few mm off when it was machined so they compensated by mounting the pegs at different heights, which isnt a big deal considering price but id rather have them even if its just my error during install. everything is mounted up correctly though so its gotta be a machining error
Old 01-31-2014 | 09:37 PM
You're not measuring off the floor with the kickstand down, are ya?
Old 02-01-2014 | 11:49 AM
jscobey's Avatar
I wish I was just that dumb. But unfortunately no :/ defect in the sets I guess but oh we'll. you get what you pay for. It was easily remedied by setting one peg one hole lower. Other than that I'm pretty impressed with them for a little over $150
Old 04-01-2014 | 01:42 PM
jlrutledge737's Avatar
jlrutledge737 is on a distinguished road
does anyone have a set of stock rear sets that they are not using? and brake lever lol
Old 04-01-2014 | 02:40 PM
jscobey's Avatar
pM sent
thedeatons
06-09-2014 03:13 PM
dallard2
04-24-2014 07:15 PM
iscoot
08-26-2007 07:52 AM
VTRBandit
05-13-2007 10:01 PM
