Paging Shayne - Powerbronze Windscreen Mod
Old 07-05-2006 | 07:26 PM
Shayne,
I have the Powerbronze screen as well. Read in another post that you countersunk the rubber inserts somehow. What tool did you use?
TIA,
Old 07-06-2006 | 09:59 AM
Okay, I'll try a PM then.....
Old 07-08-2006 | 05:24 AM
shayne's Avatar
Hi Greg, sorry for not replying sooner, but I haven't got on here recently as much as I used to.
I used a die grinder, what you guys call a dremel I think. I just used it enough to sit the rubber grommet level, which then allows the fairing to sit flat with the screen. The few aftermarket screens that I have seen have this problem
It is a bit tricky, as you need to keep and small it neat so you can't see it.
inderocker
05-05-2010 09:10 AM
little squirt
05-09-2009 11:24 PM
Galaxieman
11-17-2008 01:28 PM
divingindaytona
04-17-2008 06:26 AM
Sgt Rock
10-07-2007 06:26 PM
