License Plate Light
Old 06-16-2005 | 05:17 AM
2Phaast's Avatar
2Phaast is an unknown quantity at this point
License Plate Light
Anyone got any advise on how I can light up my license plate since the stock light was removed when fender plastic cut back. I'm hoping to find some kinda aftermarket rear brake light assembly which incorporates a license plate light since my plate is now directly beneath the tail light assembly.
Old 06-16-2005 | 10:08 AM
superhawk22's Avatar
Re: License Plate Light
I can't see what your tail looks like but you can find LED lights in pretty much any shape, size and color. They're ussually pretty easy to install and you can find some really bright ones. Make sure you look at them first though as some are as bright as a chesp night light.
Old 06-16-2005 | 01:32 PM
blokeontheend's Avatar
blokeontheend
I've heard you can drill holes under the brake light to allow illumination. Also look at www.targa-acc.com or www.customdynamics.com for custom lic plate led's.
Old 06-17-2005 | 09:25 PM
i was thinking of modifying the underside of the tail light to make it clear. so it would shine it's beautiful light down on my license plate
Old 06-22-2005 | 03:06 AM
2Phaast's Avatar
Thanks everyone for all the great ideas...... Can't wait to do something.....
Old 07-22-2005 | 12:49 AM
Originally Posted by jvhy";p=&quot
Hi!
I have '98 Firestorm (euromodel) and it has a transparent downside in taillight! No separate licence plate light...(will post a pic soon...)
Don't know when that light went separate, though...I believe it's separate in newer models in here too!
Go search through ebay! I believe that taillights are interchangeable between different years...
-Janne (VTR1000F '98 & RG250W '84)
so where are the pics of the light.. also.... where can i get one... i've looked on ebay and only found u.s. versions...
Old 07-22-2005 | 10:33 AM
holy crap!..... so where in the hell can i find one?
Old 07-22-2005 | 11:55 PM
yellafella's Avatar
yellafella
How about this ? dont know how much shipping would be though ? Got a spare one myself but am looking to modify it to incorporate indicators too.
http://cgi.ebay.co.uk/ws/eBayISAPI.d...987038613&rd=1
Old 07-23-2005 | 12:29 AM
is that small hole in the red lens? if so i'm sure i could combine that one and mine to make a nice unit
Old 07-23-2005 | 12:46 AM
yellafella's Avatar
yellafella
It will most likely be the same as mine, where the led is fixed into a small hole at the rear of the light unit ( black plastic ) If you dont use it then just plug it with sealant.
Old 08-01-2005 | 08:34 AM
VTRFISH's Avatar
VTRFISH
I altered my stock tail light to light up my plate. I used a dremal tool to cut out 80% or so of the flat area on the underside of the tail light. Cut a piece of clear plastic from a CD jewel case to fit and clear RTVed it in place.
Mike
Old 08-01-2005 | 08:57 AM
v2weapon's Avatar
v2weapon
Why not just switch to a clear taillight lens? Ebay, Lockhart-Phillips, and Parts Unlimited are sources for clear lens kits. 8)
Old 08-01-2005 | 09:21 AM
VTRFISH's Avatar
VTRFISH
Clear lens kit is cool
But.....
Lens kit.....approx $50....or more with LEDs
My "El Cheapo" conversion..... Used jewel case that was headed for the garbage can....a bit of RTV.....time....... Total cost.... 50 cents?
8) 8)
Mike
Old 08-01-2005 | 10:58 AM
well for me... i personally like the red rather than the clear tail light
Old 08-01-2005 | 05:32 PM
GoBlu's Avatar
GoBlu
I have a set of brushed stainless plate bolts that have a LED in them. They have directional slots to alow you to aim the beam of light onto the plate. They cost about $30. They look great.
Old 11-11-2005 | 05:33 PM
CNI Dawg's Avatar
Found these & ordered some.
Will let you know how it turns out
http://www.1tail.com/sa/p/Lite_N_Boltz_domed_head_license_plate_light_-_Satin_Finish_(pair).htm
Old 11-16-2005 | 09:44 PM
motojoe's Avatar
Sexual Daredevil
I have a set of "DEI Lite'n-boltz" installed on mine. They work great. $22.99 per pair.
Totally legal. I got them through www.4wd.com
What can I say, I'm a Jeep nut too!
Old 11-16-2005 | 10:54 PM
heres what i finally did. i found a cheapo' small interior light a checker auto parts, spray painted the housing flat black and whamo! instant light on my plate.
Old 11-21-2005 | 08:27 PM
vtrstunta's Avatar
vtrstunta
ill sell you my liscense plate light! for real though... i dont need it.
Old 11-22-2005 | 05:01 AM
woodman's Avatar
woodman
I just took the stock license plate light, removed it from thr plate bracket and mounted it up under the tail light where the reflector was.
nophr
02-03-2011 07:52 PM
Anto
09-12-2009 12:47 PM
Anto
05-05-2009 06:20 PM
CNI Dawg
07-01-2006 05:05 PM
Vincent
05-26-2006 03:33 PM
