LED Taillight Issue - VIDEO!
Old 05-03-2008 | 01:33 AM
Recently 3 of the 6 license plate lights started flickering non stop. it does it with the engine running or off. Any body with some LED/electrical experience have any idea if this may be fixable?
Old 05-03-2008 | 06:52 AM
looks like a strobe light.... now where's my disco suit?......
Old 05-03-2008 | 09:09 AM
BlackHawk996's Avatar
i support twins
maybe a loose connection or a loose wire at those lights although im not really sure
Old 05-03-2008 | 09:19 AM
supermonie's Avatar
Hawk Newbie
X2 Check your splices or make sure connecters are snug sometimes you can use zip ties or electrical tape to keep the connecters tighter together.
How long have you had this light?
Old 05-03-2008 | 10:55 AM
Triple checked all 3 connections. I bought the light back on 11/07.
Old 05-03-2008 | 11:31 AM
Gregw's Avatar
Just thowing this out, may be some bad soldering on the circuit board.
Old 05-03-2008 | 11:49 AM
supermonie's Avatar
Hawk Newbie
yeah if your wiring is good something then it is the light if you are handy open the light up and check out the soldeing inside. I hope this does not happen with my light in the future. I just installed mine.
Old 05-03-2008 | 11:52 AM
LED's as a component doesn't fail by flickering... they outright fail, like a light...
However a bad solder on a curcuit acts like a thermal switch... contact=heat=bending=no contact=cools of=contact... and loops over and over...I have seen it happen before, typicaly on arrays of diodes where the power output is a bit more...
I'd start by resoldering all connections that are unique to that bank of LED's as they are likely to be isolated from the next 3... This as grouping them 3 & 3 seems logical when using 12v....
Old 05-05-2008 | 08:38 AM
cljackson99's Avatar
Redtail Raptor
cljackson99 is on a distinguished road
Not that this is entirely related, but I bought a set of 194 inverted led bulbs off Ebay for the running lights on my Hyundai Elantra. They worked well for about a month before they started strobing obnoxiously. I believe the seller blamed the heat build-up from the headlight assembly as the reason for their failure. They're tiny sealed units, so there's no way to see if they can be fixed.
Needless to say, I'm not replacing them with another set of leds, as I suspect there are a lot of low quality leds being sold out there. Don't know if that applies to motorcycle applications.
Old 05-05-2008 | 09:13 AM
blackvtr's Avatar
blackvtr is on a distinguished road
it's absolutely a bad taillight, throw it away and get a new one. i have the same problem with a strip of parking lights on the left side of my taillight, but i live with it. but will get a new one soon....
Old 05-07-2008 | 08:46 PM
joshb488's Avatar
Super Chicken
joshb488 is on a distinguished road
okay this isnt going to help your problem, cuz id be on here asking the same thing if that happened to me, but where did you find that light? its pretty awesome, and i cant find much stuff available for these bikes
Old 05-07-2008 | 08:55 PM
VTR1000F on eBay
Old 05-09-2008 | 11:36 AM
spencerlvevacque's Avatar
spencerlvevacque is on a distinguished road
dammm I bought the same one. Hey by any chance did you have to wire in a fuse to slow the blinking down or is there already one built in?
Old 05-09-2008 | 12:50 PM
you'll have to wire in a resistor.
Old 05-09-2008 | 02:14 PM
By any chance would you remember what kind of resistor? LIke size wise?
Old 05-17-2008 | 11:38 PM
haknslash's Avatar
You can get alot of stuff here http://www.autolumination.com/. I used to buy from this place when I did a LED swap in my dash on a previous car.
He sells LED load equalizers which is a resistor like mention above that fixes the fast flashing. They get hot from what I hear so just take that into consideration.I can't find them on his site list but they are burried in there somewhere.
I searched on google and here is what came up http://www.ledlight.com/detail.aspx?ID=39
Old 05-18-2008 | 02:30 AM
KindredGhost's Avatar
KindredGhost
KindredGhost is on a distinguished road
yeah, mine started doing that, till they completely failed. The brake light/running light/turn signals work fine... but yeah... no more license plate lights. I'd write more, but i'm hung over.
kG
Anto
09-12-2009 12:47 PM
Anto
05-05-2009 06:20 PM
handkaudio
07-20-2008 08:29 AM
epleeds
06-05-2008 06:50 AM
mamisano
04-03-2005 01:41 AM
