LED front turn signals
Well if you just replace them they will blink faster than before (maybe too fast).
You can either swap the flasher with one that compensates or you can add resistors to the circuit to make the LEDs work with the standard flasher.
Yeah,when you mount LED's the flash rate will speed up.If you want them to flash at a stock rate you need to change the flasher relay.I got one for $20,can't remember where I got it,but google is your friend...
Magnus
05-29-2014 07:52 PM
johnclopp85
05-13-2009 08:20 AM
iamanonymous
09-05-2006 01:56 PM
2002, accessories, body, homemade, honda, intergation, led, light, motorcycle, signal, signals, superhawk, tail, turn, vtr1000
