Integrated Tail Light mounting question
Old 05-23-2015 | 06:47 AM
laxcuz's Avatar
laxcuz is on a distinguished road
Hey all,
I'm running into an issue trying to mount my integrated tail light. The brackets that are under the rear cowl are snapped off so that is not an option. The previous owner mounted it using a single screw into the plastic fender liner which is not holding it in place. Does anyone have an alternative method of mounting an Integrated tail light?
Old 05-23-2015 | 10:13 AM
I had this exact issue early on with my bike. How good are you at fabricating mounts with epoxy and chunks of plastic? Or, have you ever plastic welded before? Easiest, but probably the most expensive solution, would be a new (used) tail fairing. Maybe post a wanted ad in the classifieds here.
SuperMike
08-08-2014 08:46 AM
Bearshawk
08-07-2014 06:46 AM
Mattaua
10-27-2010 05:07 PM
Hawk2445
06-24-2009 07:54 AM
seaton001
03-19-2007 06:46 AM
