Front Turn Signals
Old 06-17-2007 | 10:03 PM
Front Turn Signals
I need some options, opinions, advice. After I put the new fairings on I could not bring myself to install the stock front blinkers/running lights. I would like to retain the funtional running lights and signals so I'm not sure the LED flushmounts will work. I also hate the fit - don't wanna hear about no hot frying pan on my new fairings
$64 question is next:
Other than new stockers, are there any post-type mounted signals that any of you have used or seen that would do a reasonable job of replacing the stockers? I have the grommets for the fairing cut-outs so it will be stock in every way.
I have considered sanding my stockers down and just do the Colorite rattle can re-finish on them. What I would really like is something that's a little more sleek, a little more tucked and a little more 3d than the stockers.
Any ideas would be appreciated!
Old 06-18-2007 | 09:58 PM
I would recommend against LED signals unless they are facing forward. LEDs are too directional and an LED flushmount would be useless and not seen at all from the front.
That said, the incandescent LP IV flushies are not that bad. Yes, they do require modification to fit between the inner and outer fairings, but you modify the signal itself on a hot pan, not the fairings. I understand though, the memory is the first thing that fades.
I had some really nice comments on my 1000RR LED signals at the SHOG Rally. They are made by Shock Racing but I don't know if they would be compatible with the Superhawk. The stems on those are quite skinny and would look out of place with the large hole in the fairing. But these signals are RIGHT THERE, RIGHT NOW. Nobody has any doubt which direction I'm going. They will also require use of an aftermarket flasher or flash equalizer from www.VFXkits.com.
Old 06-18-2007 | 11:01 PM
jbaxx's Avatar
Honducati
Shockracing short stalks.
Old 06-19-2007 | 09:25 AM
KC-10ENG's Avatar
I have some really small oval ones that I got from lockhart. They just cover the hole in the fairing and are secured using a big plastic nut on the back.
Super
Old 06-19-2007 | 09:34 AM
YellowHawk2k1's Avatar
YellowHawk2k1 is on a distinguished road
Proton Flushmount
check these out...
http://www.newenoughhp.com/parts/turn_signals_and_led's/high_tech_speed/proton_light_flush_mount_led_motorcycle_turn_signa ls.html
Old 06-19-2007 | 10:20 AM
nwellinghoff's Avatar
nwellinghoff is on a distinguished road
Where is the best place to buy the LP's online? I've looked around and havent found any sites with them?
Old 06-19-2007 | 12:26 PM
KC-10ENG's Avatar
Checkout www.cyclegear.com They might have what you are looking for
Dennis
Old 06-19-2007 | 09:56 PM
Originally Posted by YellowHawk2k1
check these out...
Those won't work on the Superhawk. The stock signals mount to the inner fairings. The ones you posted are for newer bikes that have signals mounted on the outer fairing.
Old 06-19-2007 | 10:14 PM
This is good ****. Obviously hacked on a box but if they can deliver the product I could give a ****. Do you own a set of these. Injection molding is sooo profitable after you make the mold.
I had an office next to some guys that had CNC machines and cut these molds all the time. I don't mind a little Dremel on the fairings to make it look right - short stalk - lense just clears the fairing - has a forward look - I'm all good. But it's one of those repairs that you can spend countless trips to run down parts. Or buying parts endlessly on the internet to get **** on like a catbox.
I was just looking for suggestions and I will check out the links and certainly appreciate all the advice.
Old 06-19-2007 | 10:18 PM
And New Enough has a good face on the street and a good Texas company. No, I don't own stock.
Old 06-20-2007 | 04:53 PM
Dude, those fit inside and mount to the recess of the outer fairing. Ours are just a hole in the outer fairing, thus nothing to mount to....unless you want to epoxy/fiberglass some sort of plate to the back of the fairing.
Old 07-01-2007 | 12:21 AM
KC-10ENG's Avatar
http://cgi.ebay.com/ebaymotors/00-06...34084766QQrdZ1
Here you go these will work on the Hawk
Old 07-01-2007 | 05:41 AM
mhutch's Avatar
mhutch
http://watsendesign.com, By far the best looking flush mount turn signals I have ever seen. Very bright front and rear.
Old 07-01-2007 | 08:43 AM
After hounding the local stores I settled on these from Motrax. I got them at Cycle Gear.
The only angle they could look better is directly from the side.
Old 07-01-2007 | 09:28 AM
MarineHawk's Avatar
I'll second www.watsendesign.com Very much worth the money and they look beautiful on the bike.
They have 2 design options, the 10- and 3-LED, I use the 3 because it doesn't stick out from the fairing as much (perhaps 3/4 of an inch less?) and is as visible as any safety guru could hope for.
Old 07-01-2007 | 10:02 AM
J.J.'s Avatar
J.J. is on a distinguished road
those are the LP IV's
Old 07-01-2007 | 10:23 AM
I like the Watsens but $140 for signals? For me that's about like a $400 hugger!
Old 07-01-2007 | 08:54 PM
do the turn signals for the RC-51 mount the same as on the VTR? just curious...
Old 07-02-2007 | 12:11 AM
KC-10ENG's Avatar
I have the same ones on the RC on ebay on my bike. They are extremely easy to install. As far as the stock mounting I have no idea.
Dennis
Old 07-02-2007 | 06:53 AM
the reason I was asking is because the proton signals that I posted earlier have a model designed to fit the RC-51. If they would fit the VTR also I might have to pick some up. I have the LP IV's on now and like the way they look but the protons are led and have the capability of retaining the running lights.
Old 07-22-2007 | 03:05 PM
NovaWildcat08's Avatar
NovaWildcat08
I just brought my bike in for inspection and they wouldn't inspect it with flush mount signals. Has anyone else run into this problem? I'm pissed because now I have to purchase signals to DECREASE the appearance of my bike.
Old 07-22-2007 | 03:59 PM
Go somewhere else.
Old 07-22-2007 | 08:46 PM
Yeah, I agree, this is bullshit. Find another inspection station and try again.
Old 07-23-2007 | 10:37 PM
GrayHawk's Avatar
GrayHawk is on a distinguished road
The Watsens are great. You should also check out the LED signals by Rizoma. They are a German company, and quality is superb. There is an importer in Kentucky who I highly recommend, but can't provide info on just now. Maybe an internet search will turn him up. As soon as I come across his info, I'll post it. I believe he's in or near Danville, Ky. The Rizoma's are a little pricey, but less so than the Watsen's, I believe about $30 each.
Old 09-13-2007 | 10:54 PM
GrayHawk's Avatar
OK, sorry for the delay. This guy carries Rizoma accessories:
http://www.pjsparts.com/
PJ's Parts, LLC
156 Buena Vista Estates
P.O. Box 661, Burgin, KY 40310
Phone (859) 748-9335
He's great to do business with - highly recommended!
Mike
Old 09-15-2007 | 02:50 PM
Ohio Hawk's Avatar
I installed a pair of those Proton lights on my RC51 and they mount from the outside with a large washer on the inside just like my Superhawk... not sure if the hole in the body work is the same but if it is they should work fine on a Superhawk.
Old 09-15-2007 | 02:56 PM
Ohio Hawk's Avatar
Flash,Run.
Old 09-15-2007 | 03:02 PM
Ohio Hawk's Avatar
Also they are dam bright from the front for a flush mount.
Old 09-15-2007 | 05:28 PM
Ohio Hawk's Avatar
Ok I was curious so I removed one of my flush mount turn signals from the Superhawk and tried the stock RC51 grommet in the Superhawk and it fit perfect... So I would say Proton lights for a RC51 would work just fine in your Hawk.
Robin427
03-16-2012 03:50 PM
Robin427
03-16-2012 02:18 AM
johnclopp85
05-13-2009 08:20 AM
snowman666
04-17-2007 07:58 AM
