frame polishing??
#32
Re: frame polishing??
Polishing is time consuming. But, if done right it will definately change the attitude of your VTR. I polished my frame and swing arm 5 years ago. It still looks sharp. It took my about 40 hours of sanding and buffing. Now I just maintence polish once a month. Sooner if I am going to a show. I used a buffer polisher with varying stages of sanding discs. Those extrusion lines in the frame are a huge pain. Then I went to a rough cut jeweler's rouge, next a fine cut rouge, finished off with a metal polish(Mother's brand metal polish works well). I used both an electric drill and a Dremel tool with buffing wheels. I now use Wizard's brand two stage metal polish and sealer once a month now. I stripped the bike down to the frame and engine. I still take the plastic off when I shine it up now. The frame looks good with the Pearl yellow plastic, polished stainless pipes, and chrome rims. Once you start don't stop. You will be happy when your done.
#33
Hey guys. I am having hard time with the rough parts of the frame by the seat. I cannot get rid of the pits in that rough part. It seems like I need to start with a lower grit than a 100. Can I do that? Is it supposed to be wet or dry when you start your first grit? I have been at it for 4 hours and I can still see little pits in the frame. I think I need to go to coarse grit. Any input?
#34
You are going to need to start off with a very corase grit and get the metal smooth first. Then progressivly with less grit like normal but it needs to be smooth first. You might need to use a grinding bit.
#36
That would probably be a good starting point. See how it goes, make sure you get it smooth. Start off dry, you only need to wet sand in the finishing stages. HAPPY SANDING HAND CRAMP!! HAND CRAMP!!
vtrlvr
04-09-2007 11:52 AM
