Carbon Fiber Case Cover?
I got a little to anxious to get the bike out even with a little bit of ice on the roads. Long story short, right case cover took a beating but managed to save all the plastics, pipe, etc... So, I've seen them before but can't seem to find them now. They are protectors made of carbon fiber / kevlar for the left and right side cases and I think that not only would it add protection but also help mask the results of my stupidity.
Anyone know where I can find these? Thanks in advance
I already asked this question a few weeks ago and got no responses. Good luck and PM me if you find any.
I am thinking about making some myself, shouldn't be too hard. Google DIY carbon fiber, resin and fiber sheets are not that costly, and I would think it is easy to cast the cases in clay, then cast a positive in plaster or something and vacuum form it in a plastic bag.
If I get around to it, I will post about it.
You might want to check www.thurn-motorsports.de/html/sc36.html. I had it saved as a favourite place under the heading "vtr case covers." I had problems getting into the site to confirm it. Hope you have better luck. Sorry about the incident with your vtr.
Followed the link down the rabbit hole to a final distributer.. good link, though.
Not a bolt on type but a sturdy carbon cover that you stick on. I've crash tested them on my track bike and they stand up to some proper abuse... 50mph lowside and hardly a mark on them....
They are made in Germany. They do take a little bit of time as they are made to order.
Email this chap and ensure you specify a Firestorm...he might send you ones for an SP..
adalbert strzebinczyk <carbonadi1@yahoo.de>
Just some Wurth silicone sealant, the 180+degrees stuff. I think because of the stickiness rather than the heat... If yo use quite a lot, it doesn't come off easily!
98VTRrider
08-31-2011 04:02 PM
StuDaddy
08-15-2010 10:26 AM
Scumbag
08-24-2006 05:18 PM
