bar end removal?
bar end removal?
Alright guys well i tried to put on new grips and bar ends the other day and I found this on the end of my grips and im just curious how do i remove that little black round piece and then should the bar end just go on no problem? Its a 98
and then if anybody knows what lower this is? its awesome i want to buy it haha
Thanks a lot guys
Pawel
Thanks a lot guys
Pawel
no the piece is there without the grip on, its on the end of the bar its hard plastic and just round, so i just wondering if anyone else has seen that. Ill try to unscrew it otherwise im really not sure, thanks for the thoughts guys anymore would be great!!!
You're drawing is of a Coerce clipon. Don't cut it off. Trim a hole in the new grips and slip them on with the plastic end-piece protruding from the hole. These are good bars for the track or if you crash alot because you can replace only the bar (used to be $10) without replacing the whole clipon. If you have a slight mishap these bars skid as well as any frame slider. The plastic is VERY hard.
Some chopper bars I've bought in the past had little half circle plastic plugs so that when you whacked the size of the bars down you could stuff them back in and hide your hideous hacksaw job. Should also be able to razorblade a hole carefully in the end of the grips if they wont go on far enough if you cant get that thing off.
No, you cannot use a different bar end on these bars. If you want to go back to stock bars just ask around here - I'll bet that are plenty to be had for cheap. They have all the weights and fittings that can be ordered from Honda (if they don't come with them). Then you can install barends and grips of your choise.
Another thought to getting out the plug is to run a deck screw or something similar into the plug and then pull it out. Shouldn't be too difficult, but, as already stated above, sounds like these aren't OEM.
Alright guys thanks a lot for all the help, does anyone know maybe why the last owner could of installed these? someone said they were for track possibly lol but thanks a lot for everything if anyone knows the lower still, please let me know that thing looks great!
Gabe
04-04-2015 12:26 PM
