View Poll Results: VTROTM FEB
lloydievtr
50.00%
Tweety
50.00%
Tebs
0%
Voters: 24. You may not vote on this poll
VTROTM february 2013
Old 02-01-2013 | 03:45 PM
lloydievtr's Avatar
road racer v2 power
Congratulations to Tweety for winning the february 2013 VTROTM!
Last edited by lloydievtr; 03-02-2013 at 12:20 PM. Reason: poll set up and to let members know
Old 02-03-2013 | 09:11 AM
lloydievtr's Avatar
road racer v2 power
looks like i will have to start if off this month
lloydievtr
1998
green/black
mods are
suspention / brakes
1992 fireblade forks with weighted springs .
1992 fireblade yokes (trees)
renthal ultra low bars will bar clamps
cbr600f41 front brakes hh pads
braided brake lines front and back
braided clutch line
cosmetic
triumph rullett green with black number board
fireblade front fender
renthal grips
stubby brake and clutch levers
r1 mirrors
bubble bubble light smoked screen
hugger
belly pan painted black
under tray
seat cowl
titanium generator caps
head light kit 100/90 bulb
led stop/tail bulbs
mini indicators
didgi gear indicator
lots of stainless steal nuts and bolts
performance
quick action throttle
return throttle cable removed
lightened flywheel
2-1 exhaust with leo vance carbon ovel race can
cbr600 stick coils
fully modified air box
doctor honda velocity stacks
k&n filter
dyno jet kit
-1 tooth front sprocket
manual ccts
r1 reg/rec
+4'ignition advance
heavy duty ebc clutch springs
Old 02-03-2013 | 07:17 PM
cybercarl's Avatar
How's anyone going to be able to compete against Kermit. Unless we have a miss piggy amongst us LOL
Old 02-11-2013 | 06:53 AM
chemomche's Avatar
chemomche is on a distinguished road
My bike will be in a poll soon, just wait to finish some more mods
so she is ready to win....again
Old 02-11-2013 | 09:37 AM
lloydievtr's Avatar
road racer v2 power
looks like im going to walk away with it this month lol
is there no one else ?
Old 02-11-2013 | 10:07 AM
CrankenFine's Avatar
Love the lime green look! But you could tell I am partial to green.
Old 02-11-2013 | 10:31 AM
Well... We can't have you winning by default now, can we... Let's at least make it interesting... I'll be the miss Piggy to your Kermit...
The owner, that'd be me then...
Model year is 1997, but if you calculate out the average of the parts, it ends up somewhere around 2003 I think...
Color, the stock to R157 Italian Red, on most parts, and the hugger and undertail in Gloss Black...
Modifications (the one's I can remember):
CBR 1000RR fork:
- CBR 1000RR USD fork (Reworked with Öhlins internals)
- CBR 1000RR wheel with 320mm rotors
- CBR 1000RR complete brake (Radial M/C, radial calipers) with braided lines
- CBR 954RR/929RR triple tree
- ConvertiBars adjustable clip-ons
- Moved the radiators 1" back to make room for the fork
CBR 1000RR instrument cluster:
- CBR 1000RR temp sensor (Replaced ECT)
- Integrated gear indicator (build and design by me)
- Integrated fuelgauge & charging indicator
- Integrated gear indicator (Home made, in progress)
- Speedohealer (v4)
RC51-SP2 swingarm:
- RC51-SP2 swingarm with custom welded lower link mount (Idea from hawkter996)
- CBR F4i rear shock (Modified with heavier spring and custom internals by Jamie Daugherty)
- RC51-SP2 rear caliper & caliper mount
- CBR 1000RR rear wheel & sprocket (6" with a 190/55 tire)
- Custom mount plate for rearset at the pivot bolt
- Custom rearset (parts from cheap eBay set and some custom made parts)
Fairing:
- Dark tinted DB screen
- CBR 954RR OEM hugger
- Mototeck undertail
- GSXR Mirrors, with signals in them (Custom made mount from scratch)
- T-Rex sliders
- Delrin sliders on both wheel axles
Electrical:
- HID projector (Nissan G35) High & low beam.
- Brake light modulator (build and design by me)
- R1 Mosfet Regulator/Rectifier Swap
- Peugeot 206/307 flush mount indicators
- LED plate light in Mototeck undertail
- LED taillight Retrofit (Idea from haknslash)
- 8 pack of A123 cells replaced the battery ("Home made")
- Moved ECU & CDI to the battery box with the new smaller battery
- Improved wire harness with more ground points
- Suzuki Hayabusa handlebar controls (Gives me warning lights and moves the light switch to above the start button, great for killing the HID before cranking)
Engine:
- Custom one of a kind cam's
- Adjustable Cam sprockets
- Ported & flowed heads
- Lightened flywheel
- BMC Street airfilter
- FloCommander
- Aluminum velocity stacks
- DIY Manual CCT's (bolt through drilled out stock CCT body)
- Moriwaki Highcomp Pistons
- Moriwaki Oz valves & springs
- Reinforced Crank & Rod bearings/seats
- EBC Heavy duty clutch springs and plates
- Factory Pro Shiftstar, spring and detent kit
Misc:
- Sargent seat
- Aluminum front fairing stay & rear subframe (custom made by me)
- Jardine Aluminum high mount slip-on, removed muffler mount from stock rear footpegs and spaced them out
- 16/42 gearing
- Short throw throttle
- Adjustable and folding brake and clutch grips
- Custom made mount for my disc lock (I got tired of opening the seat to store it)
Things I haven't gotten around to finishing quite yet:
- VFR 800 fuel tank (Still need to fix the joint line with the seat, not willing to cut on the Sargent seat...)
- Öhlins steering damper (I didn't need one before, but with the high rear and slightly lower front the bike is a bit prone to headshakes on corner exit if I push it...) Still need to find the correct parts to match up the 929/954 triple and VTR frame...
Plus a whole bunch of little things I already forgotten... I'm on my second round of re-doing mod I forgot I had done now... Or it could be the third?!?
Old 02-11-2013 | 10:36 AM
Tweety you seriously should update the pics on that thing... I think I saw all of those when I was researching VTR's before I bought mine, haha!
Old 02-11-2013 | 11:08 AM
I`ll throw mine into the hat again after the next round of mods is done (namely ZX-10R forks,....)
Good luck to all, nice bikes so far
Old 02-11-2013 | 11:21 AM
Tebs's Avatar
Tebs is on a distinguished road
Alright since I'm already logged in and since I'm going to make some big changes this year ......here goes.....
1998
D&D black exhaust (slipons only)
Polished orig header (PO)
15/43 530 chain
15,4XX orig miles
APE CCT (ohh ahhh is that considered a mod??)
Original R/R (soon to be changed)
Fancy schmancy photographs (my riding buddy is a sports photographer)
Thanks for looking!
Attached Thumbnails VTROTM february  2013-img_2681.jpg   VTROTM february  2013-img_8599_2.jpg
Old 02-11-2013 | 12:41 PM
Yep, I should... But that includes cleaning the bike... And it hasn't been 5 years from the last cleaning yet, so I'm holding out... And besides, I'm not done with it yet...
Old 02-11-2013 | 01:23 PM
aye brother, and you never will be, lol (from one who knows.......)
Old 02-11-2013 | 01:30 PM
lloydievtr's Avatar
road racer v2 power
It's picking up now :-)
Old 02-11-2013 | 02:42 PM
1998
15/43 530 chain
15,4XX orig miles
Thanks for looking!
I like the pictures, there you go.... Red is the fastest color
Old 02-11-2013 | 04:10 PM
scottiemann's Avatar
Id finally throw mine into the mix after 7 years being on this forum but all I have to show is a heap of parts :P ... my goal is to have it done by end of march, mid april. maybe then...
good luck everyone, looks like an interesting battle this month
Old 02-11-2013 | 04:11 PM
And BTW I think its gotten to the point where we should change the name from VTROTM to OCMDOTM..
Just sayin
Old 02-11-2013 | 04:20 PM
Just sayin
If you can't beat 'em, may as well join 'em
Old 02-11-2013 | 05:08 PM
cybercarl's Avatar
Now that would be an interesting addition to the VTROTM LOL
Old 02-13-2013 | 07:06 PM
Give it a couple months and ill put mine in when its up and running
Old 02-22-2013 | 03:06 PM
lloydievtr's Avatar
road racer v2 power
only 3 votes so far how disappointing come on you lot
Old 02-27-2013 | 03:14 PM
lloydievtr's Avatar
road racer v2 power
not long left now !!
Old 03-03-2013 | 06:35 AM
Nuhu... I didn't win it... It's a tie... And that was dissapointingly PC of the lot of you...
But, I guess I actually prefer a tie... I like Kermit... If I where to re-do my bike from the ground up, I'd probably steal a few of the ideas... But not all...
Old 03-03-2013 | 07:19 AM
cybercarl's Avatar
Does this mean another poll gets set up then.
I'm thinking of entering mine for a laugh in the March VTROM. I shall have to give it a wash first and take some good pics. See how well she does before some serious customisation.
Old 03-03-2013 | 08:54 AM
Tebs's Avatar
I'm just happy I was able to get on the podium!
lloydievtr
09-11-2014 02:56 PM
lloydievtr
08-08-2013 06:53 PM
lloydievtr
05-20-2013 04:09 PM
lloydievtr
05-01-2013 09:41 PM
lloydievtr
04-29-2013 12:19 AM
