iamanonymous : 1998 Superhawk 996
heres my baby.
generic semi-inclusive list:
98 SHawk
Marchesini Front and Rear Wheels
900RR Rear Wheel
Michelin Pilot Power Tires
Aluminum Paint Scheme
Sharkskinz Street Lower Fairing
Fiberglass Rear Hugger
Fiberglass Undertail-Accepts Stock Taillight
520 Pitch RK X-Ring Racing Chain
520 Pitch 900rr Vortex 15 Tooth Front Sprocket
520 Pitch Black Vortex 43 Tooth Rear Sprocket
Race Tech .95k Fork Springs
10W Honda Fork Oil
2" Lowered Front End
1" Raised Rear With Rear Shock Spacers
Goodridge Kevlar Front Brake Lines
Goodridge Kevlar Rear Brake Line
Goodridge Kevlar Clutch Line
LP Flush Front Turn Signals
Rear Signal Integrator
Delrin Bar Sliders
Delrin Frame Sliders
Delrin Swingarm Sliders
Delrin Rear Peg Sliders
Gel Grips
Black Clutch and Brake Levers
Black Triples and Clip-ons
Solo Cowl
Zero Gravity Double Bubble Light Smoke Windscreen
Updated Regulator/Rectifier
2003 R6 Mirror Block-off Plates
BMC Street Air Filter
Factory Pro Jet Kit
Factory Pro Shift Kit
Coerce Fork Stabilizer Brace
Toby Steering Damper
Stacked Front Cylinder Velocity Stacks
EBC HH Front and Rear Brake Pads
APE Manual Cam Chain Tensioners
Leo Vince SBK High Mount Exhaust
Emblem Delete
Mirror Delete
Rear Fender Delete
PAIR System Delete
No Chicken Stripes
Tested to 165 MPH
98 SHawk
900RR Rear Wheel
10W Honda Fork Oil
Delrin Bar Sliders
Gel Grips
Solo Cowl
Factory Pro Jet Kit
Emblem Delete
Mirror Delete
Rear Fender Delete
PAIR System Delete
No Chicken Stripes
Tested to 165 MPH
dude you rock! you joined just to tell me you like my bike! welcome to the forum. yeah it's dropped a bit. i rode when it was snowy and icy here. get out there, although it sucks washing it off. my bike is usually very clean.
btw ur rear tire looks to have very low pressure there haha.
I'm sorry, but I don't like that pipe. I think you're going to loose power becaue it's too restrictive.
Why do you think Honda produces it with two canisters????
it's a BIG V-TWIN. It needs to breath.
i believe you are mistaken. the midpipe is 2" ID which is thicker than stock, but it does shoot hard puffs of air out the rear.....i also have a few questions about my jetting. btw i spent a whole 60 bucks on the setup so i dont care.
The little canister you have set up will not allow the exhaust of both cylinders to exit fast enough.
I actually think stock would be less restrictive.
Even if the inside dia. was 10 inches it still gets bottle necked at the can.
I think you wasted 60 bucks.
rob
well i destroyed the stock cans by experimenting, and the bike is fast enough to beat a race spec buell xb12r, and stay right next to a zx-10r all the way to 10k...thanks for your input, rob.
I think your 2 into 1 pipe looks great !
Nice job!
For those doubters the only way to tell if there is a power loss is to dyno it & check the results.
Watch for another dyno run special at Al Lamb's Dallas Honda.
They do 1/2 price runs sometimes. Just sign up on their mailing list.
Jim Sabin has a $30 special on Dyno runs right now!
Just found out when looking for his web site to post the link for you.
I need to do one on the 600RR - that's a cheap dyno run!
He's at I35 & Walnut Hill.
http://sabinperformance.com
He's a good guy & former CMRA racer.
Has helped me with both my old Superhawk & new 600RR
IT would be interesting to see your results.
Bet it's very close to the same as with 2 cans.
Nice job!
