KB Article #1 - Bafflectomy
#32
#35
#36
That being the case this baffelectomy should then work?
I do t want to completely remove the baffles and will only try drilling 4 holes in each to open up the sound a bit.
Worth doing and possibly ruining a good set of pipes?
#39
I'll add to thread to let others know how I did mine and it was easier than expected and did the baffelectomy while the cans were still mounted to the bike.
I bought a metal cutting hole saw that was 2-1/8 diameter and 2.5" deep.
The diameter was the perfect fit and proceeded to drill away. A minute later this was the result.
Not bad if I say so myself.
Other side was done the same and then proceeded to use a long 3/8" socket extension to insert inside the cut baffle and started wiggling in up/ down motion and also circular motion.
A few taps with a block of wood onto the now loose baffle, a few more wiggles, and out it came.
From there I got my Dremel tool with a barrel grinding stone and cleaned up the metal to have it look like this. 5 minutes both sides and looks great.
Im pretty happy with the way it came out and again quite easy to do for the baffelectomy.
Hope this helps someone out. 🙏🏽👍
#40
Available?
I have a set of bafflectomized cans collecting dust in the rafters of my garage. they are in good condition, except for having their guts ripped out
I'll sell them cheap ($50 +shipping for both), if you want to keep your stock ones original.
I would recommend a used set of aftermarket canisters over the bafflectomy.
Brian A
07-15-2006 01:45 AM
