CBR CLIP ON Hieght
CBR CLIP ON Hieght
Does anyone know which is the highest rise clip ons from the cbr's? 900, 929, 954, or 1000rr??(or is another brand best?) I am doing a front end swap & cant find this bit of info. Thanks guys.
well the 900 has the same kind of fork as the SH, so it's clipons would work with the stock front end.
The other 3 are all 50mm and I don't know if any of them would have enough rise for use in a swap. I have swatts with 3.5" of rise on mine and they are still lower than the Helibars on yruyur's bike. (unless you can put them above the upper triple, but I think you need RC51 forks for that)
No stock CBR clip-on is usable for a swap... Period... They are all to low by far...
The Suka TL stock bars work, but have a wierd angle on the bars so not for all...
Other than that you are either looking for Helibars for 929/954 or something "custom" or adjustable... Like Swatts, ConvertiBars or similar...
I ran 954RR clip on's above the clamp (854 as well) for a shirt time. They had a lot f rise, just barely making it under the fairing at full lock, but the had a pretty steep rake. I found a set of 954RR Helibars on eBay, and those were extremely comfortable, however they would hit the fairing pretty easy when mounted above the 954RR triple. I purchased an RC51 triple and was going to mount the Helibars below it, which I think would of worked out beautifully... but I ended up selling the front end before I could do that.
Indierocker: Did you have your forks pushed up higher in the triples than I do? Or were the clipons only halfway on the forks? I only have about ~10mm of fork leg above the top triple (not counting the purple cap) if I put much more than that the bike is twitchy and the fender easily hits the bottom of the fairing.
edit: pic for example
I think there is a very good write up on the 929 transplant in the knowledge base. I remember printing it and adding it to my file - lots of pictures and quite complete. 43mm tubes iirc. Minimal clearance probs.
For aggressive riders above 185 lbs this is the easy platform. Hawkrider did the 1krr transplant and I think that got him where he wanted to be. But he's real fast. Every time I get on the bike I am reminded this is like riding the gooey noodle. The engine just toys with the metal that surrounds it.
All of them definitely limit steering lock unless you do a little grinding of the steering stops and moving of the radiators.
As for running flush, I started out that way, but had a bit of "flop" into the corners that goes away completely by raising the forks those 10mm.
Letsrideinsc
03-01-2007 09:12 PM
