[ KB ] Bafflectomy
[ KB ] Bafflectomy
Category: VTR1000F Modifications
Type: How-To
Article Name: Bafflectomy
Author: mamisano
Description: Modify the stock cans for better sound and more power...
>>Read Full Article
Type: How-To
Author: mamisano
>>Read Full Article
Guest
Posts: n/a
Re: [ KB ] Bafflectomy
I altered mine with a long 3/8' steel rod, used as a punch. The additon of two extra internal holes helped a little.. .. four holes that ruptured between the internal baffle tubes was better,.. with improved fuel economy.
But when a serious assault was made on the outlet tube,.. I lost power and torque to a very noticable degree. ( It was gutless )
After having the original internals replaced with a straight through glass pack muffler I once again had power and an excellent sound. :wink: Just a bit lean.
I did need to have a Dyno-Jet kit installed, and now its at 105hp.
Guest
Posts: n/a
I performed the bafflectomy per Greg's recomendations and I found it fairly easy to do. Infact, I believe I had it done in around 15 minutes. I think a jet kit would definitely help it now, but mine seems to be running great and the sound is much improved over stock. Do not do this modification unless you want to be noticed, it is much much louder than stock.
Guest
Posts: n/a
Back in "the day" we did these bafflectomy on bikes by just pouring a bit of carosene into the pipe and "boom" lighting that sucka and burning out a bit of the baffle. Now days stuff is made so cheap it would probably blow the pipe appart. Good article though and good pics to support your idea.
Has this caused any mid range loss on anybody?
So all you're doing is taking a hole saw, cutting the first "baffle plate"...
then, taking a screw driver to wiggle around the baffle tube/plate a bit, then taking a hammer with some wood and just beating the crap out of it till the spot welds break?
Just making sure before I goto start this project.
Did you leave the mufflers on the bike or did you remove them?
Had the mufflers off & one was all rashed up, so i figured, what the heck... drilled two 1/2 inch holes in the back of the canister below the outlet.
Sounds MUCH nicer (read: thumpier), without being obnoxiously loud.
