what does a standard rear shock look like
Old 10-03-2009 | 04:38 PM
Forde's Avatar
Forde is on a distinguished road
hey guys
my rear shock has a bright yellow spring, is fully adjustable and is a showa with the respective showa decals on it etc.
it came to me on the bike, is it the standard unit which happens to be made by showa or an aftermarket unit? even if showa do make the standard one, is mine an uprated aftermarket one?
i know showa make some standard parts, but its the spring colour and decal etc that has got me thinking, it just looks aftermarket to me.
thanks
Old 10-03-2009 | 05:06 PM
Stock is indeed a Showa, and it has an decidedly ugly yellow spring... But as far as adjustable, it's got preload and rebound, but no adjustment for compression dampening and no ride height adjustment, so fully adjustable is a matter of opinion...
As far as quality goes it's actually quite good, my main gripe with it was that the front and rear suspension was setup for two different persons and I'm in the middle of the two both in geometry and weight...
Old 10-03-2009 | 05:31 PM
Stevebis1's Avatar
+1 Except it is a decidedly handsome yellow spring...
Old 10-04-2009 | 12:25 AM
Forde's Avatar
ah right didnt really check out the adjustment that much just assumed it was fully adjustable cos it looked good lol
need to get it set up, its set for someone heavier than me atm so is a bit firm
Old 10-04-2009 | 02:15 AM
Well, unless you are twice as wide as you are tall, it's always set up for someone heavier...
CruxGNZ
07-12-2013 02:32 PM
2Phaast
02-13-2011 09:22 PM
Kators
12-13-2009 07:13 AM
Involute
05-14-2008 08:07 PM
andy9743
04-08-2008 07:35 PM
