What are the benefits of helibars?
Sorry for the very newb question, but what are the benefits of helibars? I found Woodcraft 41mm clip-on handlebars for $140. I'm assuming that clip-on and helibars are the same thing.
Well a helibar is a clip-on... The difference being that they are higher and closer to you, relaxing the position... Woodcraft clip-on's tend to be lower than stock or the same... Definetly not comfort items...
If you're getting numb or tingling wrists and hands because of the riding position of the stock bars, Helibars will help . . . a little. I've learned to grip the tank with my knees and use my abdominal muscles to bear most of my weight. That way my grip on the bars is featherlight and I'm putting almost no weight on them at all. That stops the tingling, and it lets the bike take its own line through the corners more naturally. It's a good ab workout, too!
Heli-bars are higher and also allow a small degree of width adjustment ( pulled in closer to the tank or spread out towards the fairing),the stock bars do not because of the cast in lug that locates in the top triple clamp. This gives more options for comfort.
If you are looking for more comfort, also consider the convertibars. I found them a little fiddly to install, but definately makes a big difference. My riding position now is closer to maybe a Ducati Monster, still a little forward lean, but more streetfighter position.
"One other thing, if you trailer your bike you cant use Helibars as a tie-down point."
That may be the official company info, for liability reasons, but I've used canyon dancers on my convertibars, 1200 miles r/t with no movement. FWIW.
MD_Lieber
02-07-2007 03:03 PM
