washing a textile jacket?
Old 09-01-2009 | 03:38 PM
uchi's Avatar
ive been trying to find a way to do this, there are no instructions inside the jacket that i can see anywhere. so here goes, its a teknic jacket, full armor but its on the outside of the jacket, elbows forearms shoulders and spine. clearly this thing cant go into my wash machine so what do i do. just hand wash it with some laundry soap and hang it up to dry?
Old 09-01-2009 | 04:33 PM
jonnyd's Avatar
jonnyd is on a distinguished road
Try it on a little spot first. I've thrown mine (Joe Rocket) in the wash before and it didn't really clean it. I finally took mine to the dry cleaners, and they weren't able to get all the bug guts out either. Guess I should slow down.... Nah.
I'd like to know what cleans dead bug parts out of textile jackets too! I'm thinking of taking it to the car wash...
Old 09-01-2009 | 04:39 PM
If you do, please, please bring a camera...
Old 09-01-2009 | 04:51 PM
tbartley's Avatar
Remove what armor will come out and set aside to wipe off with damp cloth. Get as many bugs off with a soft brush as you can. Run some very warm, not hot, water in the tub along with some liquid laundry detergent and put the jacket in for awhile. After it soaks for a bit (that'll loosen up the bug stuff), use your hands and work the fabric. Rinse well with fresh water and hang to dry. I have a red Joe Rocket mesh and it filters coal dust through the elbow areas that turn black after awhile. I get it clean this way and if anyone on this forum is familiar with coal dust....ya know it is difficult to get out. At least this method works for me. Good luck!
Old 09-01-2009 | 05:34 PM
You guys always have the good stuff!
Getting the armor out of some of these rigs is a challenge and after washing - more challenging getting it back in. I squeeze up the armor as hard as I can and push it into the pocket. Once it's in there then you can move it around.
Old 09-01-2009 | 05:43 PM
uchi's Avatar
Great info thanks. My armor is external though and doesn't look like it'll come off. Ill try the above technique. I'm more after getting thew stink out from the couple of 110 degree weeks we had.
Old 09-01-2009 | 05:58 PM
cameron's Avatar
i wash mine in the washing machine in cold water a few times then just let it hang dry. it usually gets all the bug guts off,but it deffinetly removes the funky smell.
Old 09-01-2009 | 06:06 PM
finepooch's Avatar
soaking will loosen up the bug guts. tooth brush will finish.
i wash my jackets in the machine on a regular basis. more now that i have a front load washer.
i even wash my hockey gear in the washer. everything except shates and helmet.
Old 09-01-2009 | 06:18 PM
OK if I'm getting the picture a little more clearly - the jacket is sort of self-enclosed? In that case I would clean it like scuba gear. A bleach rinse at some point is required. Hang it up somewhere it can blow in the wind. Make sure you do a thorough fresh water rinse after you hang it up.
Old 09-01-2009 | 06:29 PM
finepooch's Avatar
bleach? i use bleach on my hockey gear but don't think i would on my jackets.
Old 09-01-2009 | 06:53 PM
comedo's Avatar
Nikwax and Granger's make cleaners for textile jackets. They're probably available at stores that sell camping, hiking and mountaineering equipment. I removed the armour from my Olympia AST jacket, washed it in a front loading washer at a laundromat and hung it to dry. Good as new. Finding something to restore the waterproof quality of the jacket is another story.
Old 09-01-2009 | 07:23 PM
uchi's Avatar
Maybe you can spray that all weather protector stuff that you put on shoes. Give it a good coat of that. Ill post up a pic of my jacket shortly to give you an idea of what it is. Its going in for a wash in the laundry tub in about 5 minutes.
Old 09-01-2009 | 07:57 PM
Kators's Avatar
Kators is on a distinguished road
I clean mine with a wet rag here at home. Gets bugs out just fine. Got to use elbow grease sometimes but, it works for me.
Old 09-01-2009 | 08:13 PM
uchi's Avatar
bugs came out no problem. this thing is really waterproof. i held the hose to it for a few minutes and it was completely dry on the inside. very impressed. that being said when i let it soak it filled up with water and weighed about 30 pounds, lol.
here are some shots of it.
Old 09-01-2009 | 08:37 PM
cameron's Avatar
thats a pretty nice jacket. so fresh and so clean LOL
Old 09-01-2009 | 08:48 PM
Looks great! Nice jacket.
I need to wash mine. My wife has washed her Alpinestars 3 times in the washer with Tide and cold water on Delicate cycle, then hang dry.
I removed the armor the 2nd time and it was a bitch to get back in position, so just leave it in. Of course on yours that's not a problem.
Old 09-01-2009 | 09:37 PM
k-d-williams's Avatar
I have always washed mine in the washing machine with Tide soap with no problems. I leave all the pads in just like i wear it. To me it is no different than riding in the rain. The jackets never say: Dont Get Wet!
Old 09-02-2009 | 01:12 AM
shayne's Avatar
Gore-Tex needs washing for it to work properly. If you have a Gore-Tex jacket then you can wash it in the washing machine and then tumble dry. You can use special washes such as Nikwax and Graingers as mentioned above.
From what I have seen, most textile jackets are NOT made from Gore-Tex. Plenty of catchy names are used to describe the materials used in these jackets, but most of them amount to a waterproof and breatheable liner, rather than a Gore-Tex outer. If you have a jacket like this then I would be careful washing it, as you may find the liner loses its waterproofing, which you cannot restore. Check with the manufacterer before you do it.
Afetr two cheaper jackets that lost their waterproofing after a while I bought an expensive Gore-Tex one.
Old 09-02-2009 | 05:15 AM
uchi's Avatar
Thanks for the info. That was actually pre wash. Most of the bugs had fallen off while hangiing in my garage and the rest came off in the wash no problem. I was more after getting the funk out. We had those couple really hot week here and it felt like I had a bucket of sweat poured inside the jacket a couple times. I checked the manufacturers site and it didn't have any instructions on there. The best I could find was hand wash hang dry don't dry clean and don't machine wash. Oh and don't use hot water. I think next year I'm gonna buy a perforated jacket. Something that breathes for those hot days.
Old 09-02-2009 | 09:12 AM
rhorsley's Avatar
rhorsley is on a distinguished road
OK, I may sound crazy, but the results speak volumes. I cleaned my Joe Rocket UFO textile jacket using a pressure washer and Simple Green. I bought a refill bottle of Simple Green for about $5 and put the pickup tube from my pressure washer in it. Then I hung the jacket on a wrought-iron gate and used the low pressure setting on the pressure washer to saturate the jacket. Rinse WELL using the pressure from a few feet away and the jacket is nearly spotless. Easy on the hands and the jacket looks almost as good as new.
Old 09-02-2009 | 09:24 AM
Forde's Avatar
Forde is on a distinguished road
all you need to do to soften bug guts is soak it, you aint soaking it for long enough, you should have to scrub that much/hard
whats teh point tryin to get every last bit out anyway when you ride your bike again itll be covered again in a couple miles
my textile jacket says cold hand wash in soapy water inside it or something like that
Old 09-02-2009 | 02:14 PM
finepooch's Avatar
another thing to do is after each ride mist water on the bugs while they're still... um, moist(?), let the water soak in for ten minutes, mist more if necessary, wipe off with a rag. this also works on your bike
Old 09-02-2009 | 02:56 PM
uchi's Avatar
With the bike and helmet I use hondas version of plexis. Do my entire helmet and front end. Fender light windscreen and the front part of the fairings. Works like a charm.
Old 09-02-2009 | 03:37 PM
Hydrogen peroxide (HP) diluted 1:3 will disolve the protien in the bug guts and can be topically applied via a spray bottle using an old toothbrush, then rinse well. Funk is another issue that Woolite for dark colors can address, again with a bit of HP. The pressure washer idea is interesting. Waterproofing can be restored with DWR type sprays like Camp Dry which does not contain silicone. Leaving a few low or no scent anti-static cloths (used in dryer but not in this application) overnight will leave your gear "spring fresh".
Old 09-02-2009 | 08:02 PM
Yeah, gotta use a calculator for this one. A 1% formula is a common sterilant. Works the same for the bike garmet. Takes the grunge out but not strong enough to weaken color.
MUHerdFan
11-11-2008 03:00 PM
streetfighter996
08-26-2007 05:15 PM
motojoe
08-10-2007 11:31 AM
ghopki1
08-03-2007 01:12 PM
dsbunton646
05-01-2006 01:03 PM
