waiting for parts sucks
Originally Posted by sprhawk neil
man dude thats what you call minor dis-assembely, what the hell happend?I think I would of had to look for a new bike before I could do that much work.Good luck and hope to hear your riding soon.
either way, there is no head damage (luckiest day of my life considering i usually get the **** end of the stick.) so i bought APE CCT's installed those, etc etc, i have to put the engine back in since i pulled it out to check out the heads, cams, valves you name it.
the engine mounts have the craziest lock nut spacer assembly the world has ever known. you need a $60 dollar tool from honda. ( wich takes a lovely 5 days to come in ) for me to complete installation of my bikes motor.
so i wait.
this is what im dealing with
these ****** lock bolts
are adjusting those spacers
what happens is, when you back those out, install the motor, and retighten them down good, your essentially stretching the fram a tiny bit, and when you pull the motor back out, it comes in, just enough so you cant get the motor in, i hope you can understand my aggrivation. lol.
WOW!
After seeing those pix, I know I lucked out when I was putting the engine back in my KZ1000. I only had to lay the engine on it's side and work the frame over it.
Good luck with the reconstruction.
I've rebuilt 3 superhawks and putting the motor back in the frame is so goddamn frustrating. I'm sure a chisel would be the perfect tool for it, but eventually the pieces do slide into alignment. Been there, done that bro.
well used an air chisle to knock them loose, they were realllllly tight, but i didn the whole thing today
http://www.youtube.com/watch?v=znqkrou465c
4 hours, beat that, even rode it around the block a little then it started raining again!
viperkillertt
04-05-2007 11:32 PM
